unable to open drivers door
Hi,i closed the drivers door as normal and when i came to open it it will not open,i have climbed through passenger side and the door CANNOT be opened from inside either,any ideas how i can open door,can the door card be removed with the door shut.I suspect the locking mechanism is u/s?
Many thanks Rick
Many thanks Rick
2004 4.8is Le Mans Blue
Mods,Speaker upgrade to JL Audio C5 650 CSI Comps,Pioneer TS-WX77A subwoofer,Lazer Pro Park.
Re: unable to open drivers door
The door card can be removed with the door shut but it is ARPITA and you have a good chance odf damaging it.(they are about £500 new or some stupid price from the dealers)
I had to do it on my last x as the door mech had condensated and rusted.
I don't know if this post helps..........viewtopic.php?f=22&t=417
I have already replaced the door carrier and removed the card in december,is there any other way of opening the door without removing door card
Not to my knowledge if the handles don't work.Is it really cold where you are? i ask as if its frozen etc it may thaw out with some help....probably stating the obvious here
but Just a thought.
![Embarassed :oops:](./images/smilies/blush-anim-cl.gif)
Thanks for reply,its actually very mild defo not frozen as i have had that problem in the past
Have just managed to remove door card,does anyone know how to remove door mech? i cant see any bolts to remove it
Thanks Rick
Thanks Rick
Rick, not sure if your problem is the same as in the link below but it may help
http://www.xoutpost.com/bmw-sav-forums/ ... -pics.html
Phil.
Current Drive:
E71 X6 30D 2011
E53 X5 3.0D 2004
Previous:
S54 Z3 MCoupe 2002
S50 Z3 MCoupe 1998
E46 330 Ci Sport 2003
Phil.
Current Drive:
E71 X6 30D 2011
E53 X5 3.0D 2004
Previous:
S54 Z3 MCoupe 2002
S50 Z3 MCoupe 1998
It's been a long while since i did mine but i never actually took the mech of. I got it open by using a flat headed screwdriver and fiddling around untill i unlocked the door (technical i know
) once it was open i could see the prblem was rust so treated it with wd40 etc and never had the problem again.
@ phil...great link that![Thumbs Up :thumbsup:](./images/smilies/smilie_thumbsup.gif)
Cheers Phil,followed the link and the door is now open,i thought i was in dire trouble this time,up early tomorrow to take out door mech and lube.Once again thanks very much
This would fit in well on the How to but not sure how to![ROFL :rofl:](./images/smilies/smilie_roflmao2.gif)
![Very Happy :D](./images/smilies/biggrin.gif)
Glad your sorted now
a how too is a great idea take a few pics when doing the job ![Thumbs Up :thumbsup:](./images/smilies/smilie_thumbsup.gif)
- ChewingBacca
As a preventative measure is there an easy way to squirt a bit of WD40 at the mechanism without stripping the door panel off?
My drivers side seems a bit stiff.
not really the mech you want to squirt is on the inside of the door sill,it is not a difficult job to remove the door card
- ChewingBacca
Thanks Rick.
