AM Signal
AM Signal
Only a minor issue, but the reception for any AM stations on my radio is pretty poor, and seems to be affected by the throttle - whenever I use the throttle the signal crackles worse. FM is fine, but I mostly listen to AM on my commute - any ideas?
Re: AM Signal
Suppressor fault is the most likely. There is one in the aerial system and I think it's in the rear somewhere. Could also be a poor connection in the aerial system - including corrosion. I think the aerials are all on the near side rear window or in the spoiler and possibly the heated rear window.
Re: AM Signal
Thanks, is the location similar to the 3 series?
http://blog.bavauto.com/10056/bmw-poor- ... er-models/
Re: AM Signal
This slide on RealOEM may help. It appears to show approx where the parts are.
