drivers footwell dripping water
Posted: Thu Jul 02, 2015 9:39 pm
by fenj66
hi all, ive had a rather musty smell in the car this week, on further inspection, and helped by heavy rain at the time, ive found a soggy front carpet and i can see water dripping down from the bottom of the fascia near to the obd port.
has anyone else come across this problem or know what the cause is likely to be?
cheers
Re: drivers footwell dripping water
Posted: Thu Jul 02, 2015 10:50 pm
by TimX5
Have you got a sunroof ?
Posted: Fri Jul 03, 2015 6:41 am
by fenj66
hi, yes i do have a pano roof.
Posted: Fri Jul 03, 2015 6:57 am
by Greydog
I had this problem after having the windscreen replaced, they had to come and refit it.
Posted: Fri Jul 03, 2015 10:38 am
by fenj66
Hmm..I'm still on the original screen with no signs of obvious damage.
Posted: Fri Jul 03, 2015 11:28 am
by Denis O
It's morph'd into a Land Rover why you weren't looking.
Posted: Fri Jul 03, 2015 4:35 pm
Could be a blocked roof drain, or screen scuttle drain.
Posted: Tue Jul 07, 2015 6:16 pm
by fenj66
yes, indeed, it turned out to be a blocked pano roof drain, the rubber outlet under the front drivers door (near the jacking point) was full of black crud and was back filling up into the car. a quick poke of a finger up the hole ( :'( ) was all that was needed to get it clear again, now to dry out the carpet and hope the smell goes. cheers all
