Sold
Posted: Fri Oct 16, 2015 1:37 pm
by Sustanon250
Sold
Re: 19" winter wheels (style 298) + tyres - new/unused X6M,X5M,X6
Posted: Fri Oct 16, 2015 2:28 pm
by amacman
First dibs .
Are the wheels all 9x19 et 37 . What is the centre bore , 72.56 or 74.1 mm .
What tyre sizes
What is the date stamp on the tyres . Check them all .
Run flat or normal .
Load index for tyres .
I hope you have 4 for that money , where are the pics of the other 2 and can you do close up of tread pattern and entire sidewall .
Posted: Fri Oct 16, 2015 2:44 pm
by Sustanon250
[quote="amacman"]
First dibs .
What tyre sizes
Yes this is for 4 wheels/tyres - they are all stored carefully at the back of the shed so I'll be able to give you all the info you ask for tomorrow once I've dug them all out !
They are 19x9 , the fronts are et37 but the rears have a wider offset of et18 - this is how they come from
BMW , the wider rear offset just helps to fill the rear arches .
Posted: Tue Oct 20, 2015 11:29 am
by Sustanon250
Quick update now I've managed to get 3 out of the shed
Tyres are Goodyear ultra grip run flat 255/50R19 107V (front and rear)
Wheels are 9x19 , centre bore front 74.1 , rear 72.6
Can't seem to find an obvious manufacture date on tyres
Posted: Tue Oct 20, 2015 11:35 am
by Sustanon250
Posted: Tue Oct 20, 2015 6:57 pm
by sid10
Hi date normally in a little circle , something like 2615 which is the 26 week in 2015 good luck !
What have you replaced it with ?
I think the off set will also work on an X6 but E70 normal and Msport will need a rebore of centres to 74.1 as they are all 74.1 pcd all round not a big or costly job though .
Posted: Wed Oct 21, 2015 5:51 am
by amacman
Not sure the 18 offset on the rear is a good idea on an E53 . The inner edge of the tyres will probably wear very quickly .
Would have been great if they were all 37 offset .
Posted: Wed Oct 21, 2015 7:09 am
by Sustanon250
[quote="sid10"]
Cheers , ill have another look for the date as ill be putting these on eBay over the weekend !
I've been told these wheels fit the regular X6 as well as the X6M and X5M.
As to what I'm replacing it with , I've ordered a new BMW M135i , the X6M wasn't being used much (about 60 miles a week) and I couldn't justify the huge insurance , road tax etc etc
Posted: Wed Oct 21, 2015 12:59 pm
by sid10
Great choice ! have you seen there is to be a BMW M2 next year ?
Posted: Wed Oct 21, 2015 1:52 pm
by Sustanon250
[quote="sid10"]
I have and I expect it'll be an amazing car , but £44k-£46k and zero dealer discounts !
I'd rather have a M235i , with some haggling you can get up to 22% dealer discount on these and with a map and high flow cat I've heard of people getting around 430bhp and not far off 600 pounds of torque
Posted: Wed Oct 21, 2015 3:46 pm
by sid10
Thats a good discount , had a go in the new 40d last week nice car but no engine noise and steering a bit vague a bit disappointed with it really but Cayenne only 5 seats and Range Rover price of a house .
Your wheels should fit an E53 aswell as I have X6 wheels on mine 19" et48 front , et21 rears .
