loose boot trim
Posted: Sun Jan 23, 2011 10:46 pm
by Smeeagain
My 2004 E53 X5 3.0d Sport (and I should have inlcuded this spec info in my last two topic postings) has loose interior trim where the internal handle (on drivers side) is located but I cant see any trim or screws to be tightened up - does anyone have any suggestions?
Smee
Re: loose boot trim
Posted: Sun Jan 23, 2011 10:51 pm
by Sanj
The door card? Tried pushing it hard back into place (around the edge of the trim)? Otherwise the white clips are snapped, missing - no biggie (eBay) and a refit...
Re: loose boot trim
Posted: Sun Jan 23, 2011 11:00 pm
by Smeeagain
sorry - to clarify its the interior grab handle in the boot (on drivers side)
Re: loose boot trim
Posted: Sun Jan 23, 2011 11:05 pm
by x555
If you mean the handle itself smee it's bolted on from the other side of the doorcard so you will have to remove the door card to re tighten it.Otherwise as Sanj says it's probably the plastic locating lugs poped out from where it's been of before.
Pull the panel away from the door gently and you will be able to see where the plastic clips push in
Looky here fella....
http://www.youtube.com/watch?v=y25x6gIIgPE
EDIT: Ignore this then
Re: loose boot trim
Posted: Sun Jan 23, 2011 11:07 pm
by Sanj
No need buddy - I'm bein the div!
Look where the grab handle is (2 screws in there) and where th elights are (unclip with the plastic nect to them with aflat blade screwdivers) and you will reveal two more phillips screws. Then, use force and kahoonaas to pull the trim away which is all on poppers.
Oh and as long as this is an E53, the above applies.
Re: loose boot trim
Posted: Sun Jan 23, 2011 11:10 pm
by x555
[quote=""smeeagain""]My 2004 E53 X5 3.0d Sport (and I should have inlcuded this spec info in my last two topic postings) Smee[/quote]
Stick this info below as your signature mate it will save keep typing it in posts and help others to help you
