Heater Controls - roasting or freezing
Posted: Wed Nov 25, 2015 7:20 pm
by X5-D-Sport
Gents...
Until recently My AC worked only when rolling, due to the AC RAD fan being dead.
Recently, the AC appears to have quit altogether... but with a twist..
Regardless of whether the AC is switched on or not, any heat setting of 17' or more results in roasting hot air from the vents.
When set to 16' it is slightly cooled with the AC on, but not much.
The AC pump clutch is engaging OK & spinning the pump just fine, the AC system is holding good pressure.
The vehicles water coolant is at a good level.... and all appears ok....
Just getting tired of being dry roasted or cold.... never any happy medium.
Any clues any one ?
My guess is that there is a cabin temp sensor that's died, or some other dead switch some place ?
Re: Heater Controls - roasting or sticky
Posted: Fri Nov 27, 2015 11:38 pm
by X5-D-Sport
No one got any ideas why my heaters are either flat out roasting or humid cold & tepit...??
Any temp setting above 17' & the cabin is roasting... regardless of AC on or off.
Posted: Sat Nov 28, 2015 3:18 am
by themoog
Your hedgehog is knackered.
