Rear suspension level sensor
Posted: Mon Apr 04, 2016 7:22 am
Hi guys
I have an issue with the n/s rear of my e53 single axle air suspension going down over a period of time, when I checked on a diagnostic it comes up with some stupid codes that probably only make sense to the dealer, however if I check the voltage at each sensor with the launch it tells me that the rear right sensor has 4.41 and the rear left only has 0.91, do you think this would indicate a faulty sensor or should I look elsewhere for the fault? Also are the sides interchangeable as in left to right and any recommendations as to where to buy the sensor at all?
