Help please needed regarding headunit fitting
Posted: Sat Sep 24, 2016 10:50 am
by X5 white
Hi I seem to have a problem of having to fit a headunit etc in my ex police car BMW X5 E53. . I went to local breakers and I was told I can not get a system to fit in this due to wiring system has changed this could have been done by poilce having there system ?
Please if anyone help me out on this one ? Would really appreciate it.
Re: Help please needed regarding headunit fitting
Posted: Sat Sep 24, 2016 11:55 am
by ianst0028
that looks like pretty standard 2003 on wiring tbh
Posted: Sat Sep 24, 2016 2:45 pm
by Steamyrotter
I would say that's the loom for the non nav system.
Known as the business system of either cassette or single cd unit and the MID
From that bit you could fit practically any after market unit as long as you have the loom adaptor to convert to the standard DIN connections.
TBH they have cut out the supporting structure for the standard equipment so it wouldn't fit properly now.
Posted: Wed Sep 28, 2016 12:37 pm
by X5 white
I need a head unit with sat nav and which I can connect to CD player ? What's the best option for me in this please?
Posted: Wed Sep 28, 2016 1:57 pm
by ianst0028
looking at your pictures your going to struggle to fit an original head unit because Mr plod's technicians have hacked the original plastic cage/supports
your going to have to forget the CD changer because as far as i'm aware there isn't an after market head unit that will talk to the original BMW changer
look at xtrons dynavin enron for replacement head units
Posted: Thu Sep 29, 2016 6:46 pm
by X5 white
Thanks for reply... That's what I get purchasing an ex police car... Uff... So they have changed the wiring system I guess? I will have a look at the link, so even if I go for after market system I can't get a cd changer? Can anyone let me know if there is one going on eBay etc please due to am still not that sure which to go for sorry for any bother
Posted: Fri Sep 30, 2016 9:54 am
by ianst0028
it doesnt look like they've changed the wiring for the car so that bit is ok
they have hacked out the plastic support for the original radio so if the original changer is still in the back it's pretty useless
you can get an aftermarket head-unit with a changer but i'd not bother with a replacement (statistically changers have the same discs in them for over 15 months)
if you google dynavin (expensive but amazing) or xtrons (cheap and cheerful) they both do a direct plug in replacement for the hole in your dash
you wont need to change any wiring both will just plug into your existing wiring
Posted: Fri Sep 30, 2016 10:00 am
by ianst0028
http://www.dynavin.com/products/n6_e53.php
http://xtrons.co.uk/pf7153bs-7-hd-digit ... 53-x5.html
i've just thrown an xtrons one into mine that i bought cheap used from ebay
the only thing i would say is that i had to get the dremmel out to curve the corners to fit properly
as soon as funds allow i'll put a dynavin in
Posted: Fri Sep 30, 2016 11:22 am
by Horizon
[quote="Steamyrotter"]
I agree, you can see where the shelf has been cut out, so no going back. The third wire is the Fakra aerial adapter.
Next up ( white connector was for the MID unit, large one is the quadlock for the radio/ tape player.
Chinese units come with 2 loom adaptors to suit facelift or pre facelift cars, the supplied canbus unit then plugs in the loom, plug in the areal and away you go, my brackets were a far as they are for the E39 I think. Just try dropping the unit in without and see how it fits first. You may be surprised how secure it feels
I had a Dynavin in mine but was the older D99 win version not android, radio sound was poor.
Posted: Wed Nov 09, 2016 12:43 pm
by Dannyh172
I also have a unit exactly like the xtron one but is by eonon. The unit itself is good for the money. It I have a problem with the radio reception? Can anyone advise if they have had the same and how they fixed it? Also waiting for funds to upgrade to a dynavin! TIA!
Posted: Wed Nov 09, 2016 3:00 pm
by themoog
If one of these aftermarket units are installed does that do away with the bm54? Mine is acting up so this may be an option.
Posted: Wed Nov 09, 2016 3:50 pm
by ianst0028
Yes
but the bluetooth on the xtrons is not the greatest for calls ...... seems pretty good for streaming music though
