Solutions
Solutions
Post by henrym3 » Wed Nov 23, 2016 9:10 pm
tricky13 how did you get on with changing your air suspension to springs???
Lyons how did you get on with your parking sensors????
Come on guys finish the threads, I would hate to have given an answer and not know I was right. We all stab and guess at an answer on the end of a computer, it's nice to know that someone got it right even if it is mostly X5sport.
Re: Solutions
Post by X5Sport » Wed Nov 23, 2016 9:25 pm
Send 'Raj' a PM.  He did the conversion a couple of years back.
Colin
Re: Solutions
Post by Colin » Wed Nov 23, 2016 10:19 pm
yes its nice to know how things ended up
05 , 30d Le Mans Blue Sport
tricky13
Re: Solutions
Post by tricky13 » Fri Nov 25, 2016 2:14 am
Well Henrym3 because you didn't ask on my original post I've only just picked up on this.
I replaced both front struts with secondhand front struts from a 4.4 x5 of ebay cost £70 took about 3 hours quite easy and the rear air springs I replaced with the coil spring kit of ebay for £200 took me about 5 hours.
I also purchased Bmw scanner software of ebay for £15, I used this to remove the error message 'suspension error' from the dash on start up, so for about £285 the cars all fixed and it seems to drive no different than before. I didn't opted for the coilovers my concern was replacing the rear spring and a shock with one coilover and all the weight of the car on just a coilover and whether that lower bolt would cope with the whole weight of the car.
Thanks for the interest
Rich
Re: Solutions
Post by henrym3 » Fri Nov 25, 2016 7:55 pm
Thanks for the reply, yes I should have asked on original post, its just it sounded more complicated, although I'm sure it wasn't as easy as you make it sound.
