3.0D Failed to start
Posted: Tue Feb 28, 2017 8:20 am
by Alan Gunn
I accidentally left the ignition on for around half an hour while changing vacuum pipes.
When i realised what i had done i thought i would run the car.
It would crank over and over but not start.
A neighbour appeared with a tin of sniff ans a quick spray later it was running.
It fired up and ran perfect took it for a run no problems at all turned off and then restarted no problem.
Ran a scan with my c310 and no new faults just the one i know about (rail pressure when starting down to an injector but never stopped it starting before).
Any ideas on why this happened.
Re: 3.0D Failed to start
Posted: Tue Feb 28, 2017 8:27 am
by Horizon
After half an hour with the ignition left on to a miracle it would even still have the dash lights come on !!!
Never mind crank over.
Charge it up and see how it goes.
Posted: Tue Feb 28, 2017 10:11 am
by Alan Gunn
It did crank over.
I must of had it cranking over for the best part of a minute battery never went down.
Posted: Tue Feb 28, 2017 10:41 am
by Smeeagain
It does sound like a battery issue. As stated, charge it up then see how it goes.
Smee
Posted: Tue Feb 28, 2017 11:42 am
by Alan Gunn
It cranked over at the normal speed with no sign of the battery going down.
What power does a diesel use with just the ignition on (after the glow/pre-heat).
Posted: Tue Feb 28, 2017 2:06 pm
by Alan Gunn
Just gone doing some shopping and started the car 3 times and evert time was just as normal.
Very strange.
