Gents, any idea which wire is the + polarity wire for my door speakers.
the OEM speaker has no markings, the spade terminals are all the same size on thr OEM connector & speakers.
Im refitting some nice Pioneer Speakers, & the large spade connector is marked + / posative...any one know which of the OEM colour coded wires is the + wire.
both wires that plug into the speaker case feom the door loom are colour coded in 2 colours each...but which is which ??
Appreciate any help here.
door speaker polarity E53 2004 D-Sport
Re: door speaker polarity E53 2004 D-Sport
I did this exercise many moons ago so please don't shoot me if it's wrong - I have the HK amp and wanted to know the pin details. Possibly the wires could be the same to the front speakers?? Think you want the mids.
Grey ½ of connector
Pin # 13 / Tweeter Rear Right door + * Yellow Pin #21 / Tweeter Rear Right door - *Blue / yellow
Pin # 12 / Tweeter Front Right - Blue / Brown Pin #20 / no connection
Pin # 11 / Tweeter Front Right + Blue / black Pin #19 / no connection
Pin # 10 / Switched +12v remote turn on White Pin #18 / no connection
Pin # 9 / Head unit output Front Right + Blue / red Pin #17 / Head unit output Front Right - Brown / orange
Pin # 8 / Head unit output Rear Right + Blue / black Pin #16 / Head unit output Rear Right - Brown / orange
Pin # 7 / no connection Pin #15 / no connection
Pin # 6 / no connection Pin #14 / no connection
Pin # 5 / +12v factory amp +12v supply *Red / green
Pin # 4 / Woofer Front Left +Blue / white
Pin # 3 / Woofer Front Left -Blue / brown
Pin # 2 / Woofer Rear Left +Yellow
Pin # 1 / Woofer Rear Left -Brown
Black ½ of connector
Pin # 34 / Tweeter Front Left - Yellow / brown Pin #42 / Mid Front Right door + *Green
Pin # 33 / Tweeter Front Left + Yellow / red Pin #41 / Mid Front Right door - *Blue / green
Pin # 32 / Tweeter Rear left door - * Yellow / brown Pin #40 / Mid Front left door + *White
Pin # 31 / Tweeter Rear Left door + * Yellow / black Pin #39 / Mid Front left door - *Blue / white
Pin # 30 / Head output Front left - Brown / orange Pin #38 / Head output Front Left + Yellow / red
Pin # 29 / Head output Rear Left - Brown / orange Pin #37 / Head output Rear Left + Yellow / black
Pin # 28 / no connection Pin #36 / no connection
Pin # 27 / no connection Pin #35 / no connection
Pin # 26 / DC ground factory ampBrown
Pin # 25 / Woofer Rear Right +Blue
Pin # 24 / Woofer Rear Right -Brown
Pin # 23 / Woofer Front Right +Blue / Red
Pin # 22 / Woofer Front Right -Blue / Brown
Grey ½ of connector
Mine isnt fitted with tweets in the doors, just the lower mids....
Try it one way, on low of course, if it pulls cone in its wrong way. Or check with an ammeter, positive means you correct, negative is reversed.
Will do
good suggestions - thank you.
