INPA using
Posted: Thu Jun 15, 2017 8:39 pm
by marinaman
Is there a page anywhere on the basics of using this INPA , i know a lot will be learn as you go as i did with the VW software but this seems more complex, just trying to get webasto going,
Found the section,  turned on metering pump,  got fuel pumped out through little exhuast,  turned on heater expecting it to burst into life,  i had the fan going and the pump but thats all ,  it still pumped fuel through exhaust while fan going.
got fault  glow control short to ground i think,
i thought this was a faulty glow burner ?  i did take it out and put 12v to it an dit lit up bright red while i presumed it was working.
Re: INPA using
Posted: Thu Jun 15, 2017 9:27 pm
You might find some useful stuff on bmwcoders dot com as it's all about....well...coding, and has a fair bit on there covering the different tools and software  :)
Re: INPA using
Posted: Thu Jun 15, 2017 9:40 pm
by marinaman
ok  thanks maybe some real generous time free person could do a write up for newbies on this system.
