SSD HDD upgrade
BSJ_Denmark
SSD HDD upgrade
Post by BSJ_Denmark » Wed Jun 28, 2017 9:29 pm
I'm just in the middle of upgrading the CIC HDD drive to a SSD drive - will expect faster start time for navigation system and multimedia.
Best regards
Brian S Jensen
E70 X5, xDrive 40d M-Sport Individual, 2012
E39 530d Touring Steptronic, 2002
E61 530i Touring Steptronic, 2005
Re: SSD HDD upgrade
Post by X5Sport » Thu Jun 29, 2017 5:09 pm
Is the HDD the slow bit, or the OS and CIC CPU though?
BSJ_Denmark
Re: SSD HDD upgrade
Post by BSJ_Denmark » Thu Jun 29, 2017 6:58 pm
Hi X5Sport
The system (CPU, ram etc.) is not the fastest system, but the harddrive isn't heloing much if it is the old mechanical type.
The upgrade makes the navigation more responsive/faster, loads faster, quicker copy of music from USB sticks etc. - and then it safes fuel.... :-) well, in these days where everything counts - the old drive consumes 1.3A, and the new SSD is only 0.3A ......I'm not expecting much :-)
Best regards
Brian S Jensen
Re: SSD HDD upgrade
Post by X5Sport » Thu Jun 29, 2017 8:48 pm
Worth doing then  :D
Can the system address the extra space or are you still locked into the old 80GB (74GB formatted) limits?
Waka
Re: SSD HDD upgrade
Post by Waka » Thu Jun 29, 2017 10:09 pm
I had read that no-one had worked out how to expand the music partition...unless you know otherwise BSJ!
Curr. - Silverstone II F85
Prev. - E70 4.0D M Sport
BSJ_Denmark
Re: SSD HDD upgrade
Post by BSJ_Denmark » Fri Jun 30, 2017 7:06 am
Regarding the 12.7GB limit in the music library, I don't think that it can be expanded
I tried to enlarge the partion to 15GB (also tried 20 and 30) but the iDrive system still shows 12.7GB, so it must be due to software limits
Not an unknown issue - Previously I worked with production of large format scanners (Contex & HP), and we had a 10GB limit on the 160GB HDD - for no particular reason, other than the software guys had found it "easier" :-)
Best regards
Brian S Jensen
PokenH00D
Re: SSD HDD upgrade
Post by PokenH00D » Fri Jun 30, 2017 11:52 am
Have a read of this http://www.e90post.com/forums/showthread.php?t=1157480
It was my next project. He successfully made the music partition larger, a bit of a task, but it works.
2010 E71 X6 40d. Pearl Silver Metallic.
Carly Pro
Waka
Re: SSD HDD upgrade
Post by Waka » Sat Jul 01, 2017 9:34 pm
Interesting stuff - thank you  ^-^
I have a couple of 120GB SSDs hanging around and was keen to try this out until I realised that the CIC disk is IDE. I know you can buy IDE SSDs but I wonder if this adaptor and an IDE disk would fit behind the front panel:
https://www.amazon.co.uk/SATA-Female-44 ... APQRSHJZSC
PokenH00D
Re: SSD HDD upgrade
Post by PokenH00D » Sat Jul 01, 2017 11:25 pm
I read a lot of stuff on this and the only real success was with the Zheino disc used by the OP
Carly Pro
BSJ_Denmark
Re: SSD HDD upgrade
Post by BSJ_Denmark » Mon Jul 03, 2017 8:15 am
Best regards
Brian S Jensen
