E83 Navigation screen gone black
Filo22
Post by Filo22 » Mon Nov 06, 2017 1:05 pm
The navigation screen has gone black on my X3, this led me to believe my screen had failed, so I tried to reinstall the updated software for the navigation system. After a couple of minutes the dvd unit powered up and the screen came to life informing me that the urrent software was the most updated version and to remove the dvd and click ok, which I did, it then said the system would reboot in a few seconds and then went black again. It never came back on, in fact the only time it does come on is when I put the sofware update dvd in and go through the process again. I'm thinking there must be a hard drive issue somewhere, any help or advice would be appreciated, thanks
Re: E83 Navigation screen gone black
Post by X5Sport » Mon Nov 06, 2017 6:02 pm
I thought that the E83 used a mapping DVD rather than a hard drive based system?  Is the map disc OK?
Filo22
Post by Filo22 » Mon Nov 06, 2017 6:15 pm
It does have a dvd drive in the back, but when i put the updated software dvd in it takes ages for the dvd drive to fire up, the nav scree then works and tells me to remove the dvd and the system will reboot when I prompt OK, it does n't reboot, it just stays blank
Filo22
Post by Filo22 » Thu Nov 09, 2017 6:09 pm
Well had the dvd unit checked today and confirmed as dead, on to ebay now to source a replacement. BMW want an arm and a leg for a new one
mistertml
Post by mistertml » Sun Dec 24, 2017 7:49 am
[quote="Filo22"]
I hope you’ve sorted your issue.
Please can you advise how the software is updated? I’m not sure what version I’m running but it looks pretty dated to me.
Thanks in advance
Post by Horizon » Sun Dec 24, 2017 9:57 am
The Mk 4 software/ firmware is updated by removing the maps disc and inserting the V32 disc and following the instructions on the screen. l( search the forum and Google for V32 )
As you say the system is Very dated, I have the latest firmware in mine and it's still looks dated.
I now wished I'd gone for a non satnav equipped car as I would have fitted an aftermarket unit.
Unfortunately all the E83 aftermarket headunits seem to use the original radio and just give you new nav and Bluetooth.
Last week our MK4 unit was taking ages to boot up and we had the black screen for about 10 mins.
I left off the cubby hole cover and had a fan heater on low running in the boot for an hour, this sorted out the problem.
Now I have all the dash lit up like a Christmas tree as I think the ABS / DSC pump/ module has gone.
More expense
mistertml
Post by mistertml » Sun Dec 24, 2017 10:16 am
My 2005 Sport didn’t have Sat Nav so it was easy to update to an aftermarket with USB input. But the boss insisted on having the satnav which I don’t use as google maps is much better.
My main issue is when I use mp3 cds and it’s a pain to search through as the track/file name isn’t listed until you select the song.
The interface is much better on my E90 professional cd play (non iDrive) as that at the very least shows the file names when trying to search.
Hope the lights is just a reset issue.
Thanks for the reply
