Car won't move need help
Posted: Sun Jan 14, 2018 8:03 pm
by Bar2
Hi all I have a 53 plate e53 3.0d auto I was coming home from work tonight car had been driving fine I got about 1/2 mile from home pulled out a junction and the car just revved as if the clutch was slipping and an error trans fail safe prog came on I pulled in and turned the car off when I restarted it the error was a way and I drove the rest of the way home just as I parked the car outside my house the error came back on I switched the car off again when I restarted it it now won't drive at all its going in to D & R but just won't move
Re: Car won't move need help
Posted: Sun Jan 14, 2018 8:11 pm
Unfortunately the most likely issue will be either the torque converter or gearbox itself unless your trans fluid level is too low to maintain operating pressure. It will go into gear but without enough pressure it won’t move.
You’ll need to get underneath to check the level (car needs to be kept level too) and also check the colour and ‘smell’ of the oil. If dark brown and burnt smelling then the couch and brake packs are slipping and the friction linings will need replacing.
Should it be a box issue then you are looking at £1,500 upwards for a rebuilt swap out.
The E53 is known for transmission failures (I had one myself with no warnings until far too late). Mine made nasty clanking noises before losing all drive.
Posted: Sun Jan 14, 2018 9:57 pm
by Bar2
I went back out to the car again tonight if I do a gearbox reset by holding down the acc pedal for 30secs then start the car it will let it drive until I move it to N or R then it won't do anything again
Posted: Mon Jan 15, 2018 9:44 pm
That just resets the throttle adaption, it has no effect on the box itself. Will it move in ‘Manual’? Sometimes they do which might at least get you to a specialist (though trailer recovery would be safer and cause no more damage if there is any) who can read the fault logs to see what is recorded.
