Front wiper problem
Bigb
Front wiper problem
Post by Bigb » Sun Jan 28, 2018 5:57 pm
Hi there, my front wipers don't work on the first setting(that has the adjustable speed) the constant settings work as does the pull down single wipe. When I flick it to the first setting it will wipe once but not again. Any help would be great. Cheers Bryan
Re: Front wiper problem
Post by X5Sport » Sun Jan 28, 2018 7:04 pm
If you have auto wipers then it’s likely the sensor has failed.  It is at the top on the mirror mount seen from outside.  The little ‘window’ should be completely clear and you should be able to see the sensor through it.  The sensor should be in contact with the glass.
If it is fogged or opaque then the auto wipe stops working.  The sensor just clips in so you can get replacements but the window must be completely clear.
Bigb
Post by Bigb » Sun Jan 28, 2018 8:58 pm
Thanks, just seen a little guide on how to fix the exact sensor problem you have described on google. I will give this a go. Thanks
Bigb
Post by Bigb » Sat Feb 17, 2018 1:36 pm
Fixed this, a new stick on sensor from eBay for £29.99 did the trick. Cheers Bryan
lezmtaylor
Post by lezmtaylor » Sun Feb 18, 2018 12:04 pm
Brilliant, and thanks for letting us know how you solved the problem, always a help and makes us feel wanted.
Lez
