Page 1 of 2
Help needed please
Posted: Sun Feb 04, 2018 7:58 pm
by X5M50d
M50d had its fortnightly valet today and tops ups.
I wanted to top up the tyres however I can't remove the valve caps that I replaced last year for the black plastic ones (they are metal caps). They seem to be welded on
Anyone else had this problem and any ideas how to loosen up?
Re: Help needed please
Posted: Sun Feb 04, 2018 8:02 pm
A drop of WD40 or light machine oil will do it, and leave for an hour or so. Metal caps look great but the metal to metal contact causes them to grow into each other because of the brass alloy usually used.
Posted: Sun Feb 04, 2018 8:13 pm
by pvr
Turn the wheels so the valves are on the top of the wheel, the release oil will drip into the caps instead of on the wheels that way.
When I had metal caps, I turned them every week to ensure they would not weld on.
Posted: Sun Feb 04, 2018 8:20 pm
Or use and earbud to apply just a smidge
Posted: Sun Feb 04, 2018 8:24 pm
by Dogzyboy
Not much help just now, but Copper grease should stop them from ceasing in the future.
Posted: Sun Feb 04, 2018 8:33 pm
by X5M50d
Cheers Guys!
Posted: Mon Feb 05, 2018 8:33 pm
by mogsyman
Sadly all too common that aluminium literally welds itself into steel.
We use both metals together frequently and have to be very careful.
It’s quite possible you may not move them but a good soak as mentioned may well help, good luck!
Posted: Tue Feb 06, 2018 10:05 am
by X5M50d
Not budging!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! >:(
Hope this does not mean new TPS's?
Posted: Tue Feb 06, 2018 1:39 pm
by mogsyman
[quote="X5M50d"]
Quite possibly.
If they've welded themselves together you're in the brown smelly stuff
Posted: Tue Feb 06, 2018 3:34 pm
by Nictrix
Do none of you check the tyre pressures every now and again?
Although there is TPMS on the car it doesn't really recognise slight pressure drops.
I check and adjust the pressures every other week so the caps don't get a chance to seize on.
Posted: Tue Feb 06, 2018 5:03 pm
by RichM50d
[quote="Nictrix"]
Really?????!!!!!!!!!!!! :blink:
Posted: Tue Feb 06, 2018 6:25 pm
[quote="RichM50d"]
[quote="Nictrix"]
I did the same when I had metal caps, and also put a smidge of silicon grease on the threads.
You could try very gently warming them too - not enough to burn you though.
Posted: Tue Feb 06, 2018 9:53 pm
by Nictrix
[quote="RichM50d"]
[quote="Nictrix"]
Yep. At the end of the day the set of tyres is close to a grand and I would like them to last as long as possible.
I also think that cars (and bikes) feel better and handle better with the correct pressures in the tyres all the time.
Posted: Wed Feb 07, 2018 10:39 pm
by Dogzyboy
I’m worried about mine now. I might have to check the copper grease is working. Either that or check my tyres every second week!
Posted: Thu Feb 08, 2018 7:50 am
by IanP
I check my bike tyre pressures before every ride out (or every session on track..), but rarely bother with the car. Sheer laziness I guess.
But I wouldnt reccommend copper based greases in this instance, vaseline or silicon grease maybe.
Or a plastic valve cap
