Fault codes
mac1986
Fault codes
Post by mac1986 » Wed Feb 14, 2018 9:46 am
hi guys,
just realised I posted this in the wrong area, should be in e70 section.
had my car hooked up to diagnostic tool, the following fault codes came up. i already knew about the glow plugs, 2 were out when i bought the car i was just waiting for more to go before replacing all 6.
mechanic has recommended that i change all 6 glow plugs and the relay at the same time. he also said to replace the backpressure sensor and change the transfer case fluid.
does that sound about right?
Re: Fault codes
Post by Alan Gunn » Wed Feb 14, 2018 11:45 am
Always change the controller when you do the glow-plugs yes.
Not sure about the other thing.
Did you clear all the fault codes give it a run then scan again as some could be old stored codes.
mac1986
Re: Fault codes
Post by mac1986 » Wed Feb 14, 2018 12:24 pm
well i just did 500 miles this weekend gone so i will most probably just take it in to get the glow plugs done and recheck the codes to see what is there. really is worth having the carly app but i think it would drive me insane!!!
