PDC Again - I know but i need some help please
Posted: Mon Apr 23, 2018 8:26 am
Eh up all!
Next project for me is fixing my PDC.
Symptoms are:-
Ignition on 2
Press P button and sometimes in stays lit no sound, sometimes is flashes and a beep is herd which then goes off.
Sensors do not appear to be working, but some do work intermittently at the rear, not so at the front???
Things I have checked:-
I can feel the pulse from one of the rear sensors when I put my finger over the sensor, cannot feel it on others.
I can HEAR the faint clicking on all the rear sensors though, albeit some are very faint.
Fronts I cannot determine as yet.
I have get access to the rear sensor and popped one out so in terms of replacing the sensors it appears relatively easy now I know which way to tug/pull/twist/lever the shroud off from the front and behind.
Questions:-
Mine is a facelift so I gather 6 of the 8 sensors are “straight” type and interchangeable and 2 are “L” shaped which fit on the front bumper corners – can anyone confirm this please?
Which sensors are best to buy on ebay , I have found a set of 4 straights for £45.00 or you can buy 4 for £27.00 – is there any difference or are they all Chinese imports ?
Would you buy all 8 sensors just to rule out this fault as I gather that the rear and front can be isolated, so I assume rear will work ok even if the front are faulty, but you cannot isolate if 1 of the 4 fail at either front or back ?
I am doubtful it’s the actual PDC unit itself, which I understand is in the rear of the boot well somewhere.
Any tips or advice welcome, I do not have access to any OBD kit to read faults etc .
Cheers again
Symptoms are:-
Ignition on 2
Questions:-
Cheers again
