When the car was brought to the front of the garage I noticed the electric air con fan was running. Having owned the car for almost a month now and never hearing the fan I thought this was odd. As the garage had been testing the system they had it set on 16 degrees so I turned up to 22 and drove home 12 miles. When I pulled up on the drive the fan was still running.
I switched off the snow flake button and the fan stopped. Once switched back on the fan started up again. Switch off engine and fan stops. Switch back on and fan starts up again.
I always drive with the air con on auto and the temp set at 22 degrees and prior to the re-charge have never heard the fan.
Any ideas and is it coincidence that the fan is now coming on or should I return to the garage for investigation.
It was a proper Bosch centre so not any of the national tyre type chains
