The Jesus Bolt
Posted: Mon Sep 17, 2018 7:49 am
by Rick G
If memory serves me correctly this bolt is a right handed thread is it not.
I have already broken one 450mm Koken breaker bar and am now trying it with a 600mm Kinchrome bar and it wont move either way.  I know it is torqued to something like 160ft/lb but this is crazy. It cracked going anticlockwise but that's it, it's not going to move either way.
Any ideas besides eating more weeties for breakfast.
Re: The Jesus Bolt
Posted: Mon Sep 17, 2018 2:00 pm
by Greydog
Yes Rick right hand thread. I didn't need to try to hard getting mine off as it hadn't been torqued correctly at the engine rebuild. So it had come loose stripping the woodruff key in the crank, I needed new crank boss, woodruff key, crank pulley and jesus bolt plus belts and tensioner's. I replaced the pulley and tensioners more as a precaution than need.
Tightening the jesus bolt you need to hold the boss I used a set of stilson's braced against the chassis, then torque the bolt up then using a degree gauge tighten a further 60 deg then another 60 deg then a final 30 deg.
I borrowed a friends 3/4 drive extension bar and still needed a 6 ft length of scaffold pipe.
So you may need to reverse the process to get it off, it's called the jesus bolt for a reason.
Good Luck
Re: The Jesus Bolt
Posted: Mon Sep 17, 2018 3:48 pm
by henrym3
This is what I needed. Jesus was it tight
Re: The Jesus Bolt
Posted: Mon Sep 17, 2018 3:57 pm
by henrym3
The locking device is probably not BMW speck but worked well
Re: The Jesus Bolt
Posted: Tue Sep 18, 2018 1:40 am
by Rick G
Thanks guys. Looks like a big feed of steak n chips is needed and I will see if the breaker bar is stronger than I am. I remember taking the one out of the M60 in the 7 series and how tight it was but just had that nagging doubt about it maybe being a leftie.
