Stereo
Posted: Wed Oct 31, 2018 1:23 pm
by Silverfox58
Hi I've an eonon stereo in now for about a year works ok but I want to put back the bmw one back in,
Well I fitted the original bmw one back in , but it turns on music comes out of one side and the screen comes on for a Minute or two , but I can't get it to do anything,
Any ideas
Re: Stereo
Posted: Fri Nov 02, 2018 6:24 pm
by Silverfox58
Ok then ,can anyone tell me what the amp dose, now I know it does the sound but what does the computer bit on the screen,
Re: Stereo
Posted: Fri Nov 02, 2018 11:22 pm
by sleepyfolk
The sound issue sounds like the usual BM54 fault, you can get them repaired at places like here
https://www.bm54.com, maybe speak to them about the screen turning off - I’m not sure if that can be attributed to the amp as well or not, I thought generally speaking the screen problems were caused by the ribbon inside that connects the screen to the chassis of the unit.
Re: Stereo
Posted: Sat Nov 03, 2018 5:50 pm
by Silverfox58
Thanks for the reply but i have 3 head units and there
All the same >:(l
Re: Stereo
Posted: Sun Nov 04, 2018 12:26 am
by sleepyfolk
Maybe it is your BM54 unit then!
Re: Stereo
Posted: Sun Nov 04, 2018 7:26 am
by Horizon
Cartronics repair them and Baris can upgrade them too, also repairs the Amps, maybe worth a call.
You may be able to send it to them for Testing / Repair. See their Website
A decent double din headunit would be my choice,( not a Chinese one. ) Kenwood or Alpine , the MK4 BMW unit is prehistoric now.
https://www.cartronics.co.uk/BM54
Re: Stereo
Posted: Sun Nov 04, 2018 4:12 pm
by dazzasgotav8
glad i found this as my nsr door speaking is not working could this be a faulty BM54 more so then a duff speaker .
Re: Stereo
Posted: Sun Nov 04, 2018 4:40 pm
Also check the large connector to the amp - called the quad lock - for any signs of corrosion or water ingress in the battery area. Both are known areas of concern. The amp is by the battery.
Re: Stereo
Posted: Sun Nov 04, 2018 6:29 pm
by dazzasgotav8
good shout will check that i assume if i no what pin or wire does what i could carryout a continuity test of the speakers from that plug , so next question anyone no which wires are the speaker ones ,,,,
