Screw in Rear Pirelli Runflat
All X3 (G01) discussions go here.
sharpharp
Post by sharpharp » Mon Feb 04, 2019 7:03 pm
Hi all,
After a pretty horrible week already with an unplanned hospital stay, I come back out to find the TPMS sensor saying the rear Pirelli runflat is underflated 1.6
I do a quick check on the tyre and found that a screw was showing about 2 inches from the centre on the inside.
Obviously I will have to see if a local independent will fix it, but my question is, can I remove the screw myself (it is sticking out about half a cm from the tyre, or do I leave it in?
Anyone know of any nation wide tyres places that repair runflats if the puncture is not on the sidewall?
snrbrtsn
Re: Screw in Rear Pirelli Runflat
Post by snrbrtsn » Mon Feb 04, 2019 7:09 pm
BMW themselves will repair runflats as long as the tyre has not been run on flat
I’d leave the screw in and proceed for repair
If you remove, you will lose pressure and risk the run on flat scenario.......
When the tyre is removed, as long as no debris is found to signify tyre has been run flat most places will repair...
Post by X5Sport » Mon Feb 04, 2019 8:35 pm
I’d leave it in too - and did when this happened to me just before Xmas. It helps seal the hole (counter intuitive I know). I just re-inflated mine for a couple of days until I could get it fixed. No harm done.
sharpharp
Post by sharpharp » Sat Feb 16, 2019 12:19 pm
Here in the UK, BMW themselves will never fix a runflat.
In the end, I got the tyre replaced. Didn't realise there was so many varients of Runflat Pzeros,. The g01 comes with K1 rated rears.
snrbrtsn
Post by snrbrtsn » Sat Feb 16, 2019 12:28 pm
Not true!
BMW repaired mine in December when it went for its Mot
Post by X5Sport » Sat Feb 16, 2019 12:51 pm
Some Dealers are only interested in the money and will tell you they aren’t fixable even though (depending upon where the puncture is & tread depth) they quite plainly are. It’s an industry problem and is why so many people have such little trust in the motor trade generally.
sharpharp
Post by sharpharp » Fri Mar 22, 2019 12:52 am
snrbrtsn wrote: Sat Feb 16, 2019 12:28 pm Not true!
Which dealership was this? I'd love to stick it my local BMW dealership if they are selective about which dealerships will repair runflats.
snrbrtsn
Post by snrbrtsn » Fri Mar 22, 2019 6:10 am
John Clark Aberdeen
Look on the Pirelli website for repair advise
I believe, as long as there is no evidence of tyre being run on flat or damage to the internal carcase the tyre can be repaired allbeit a volcanised repair is performed...
The dealer is talking rubbish - dealers don’t make tyres!
