Vibration shudder intermittent @ 55 to 75 mph
tonka332
Post by tonka332 » Thu May 23, 2019 3:47 am
My car has created a strange vibration feels like its coming from the rear
BMW X5 F15 2015
Car has started to get a vibration / shudder when I go to speeds of 55 to 75 mph
The car only some times does this.
I have had all the wheels balanced and 4 wheel alignment. Pressures are at spec.
The thing is it doesnt happen all the time, when it does it if I switch to Sport mode it reduces the feeling.
Has anyone come across his before ?
Pedro C
Re: Vibration shudder intermittent @ 55 to 75 mph
Post by Pedro C » Fri Jul 12, 2019 10:38 pm
Did you have the wheels road force balanced or on a normal balancing machine? I've found that virtually every BMW I've had a really sensitive to balancing and getting the wheels road force balanced sorted them.
larsbs79
Post by larsbs79 » Thu Nov 07, 2019 11:57 pm
Hi,did you get this problem sorted out?
tonka332
Post by tonka332 » Tue Dec 24, 2019 8:29 am
2 new front tyres
all 4 wheels road force balanced
new centre prop shaft
Still the same
next i am going to get the discs checked and change the transfer box oil
AW8
Post by AW8 » Tue Dec 24, 2019 8:34 pm
I respect your patience with this....fwiw I would have tried a similar process of elimination. Unless discs look bad I would try transfer box fluid 1st. I would think that if discs were warped you would notice greater vibration under braking. Other considerations could be a worn engine/box mount/damper. Not trying to be smart & call this one. So many possibilities. I would suggest thrust bushes but as with brake discs i would expect increase of symptoms during heavy braking.
