Water leek
Posted: Wed Dec 25, 2019 5:55 pm
by ssrfr03
Hi so I have a rear water leek in side car passenger side both sides it seems to be water holding in the rear door seals ,the rear sun roof drain holes are clear front ones are draining ok when I pour boiling water down them.
It’s as if the door seals are filling up with water an then flooding over into the rear foot wells open the doors after it’s been raining and the water will drain out the door seals any ideas please ??
Re: Water leek
Posted: Wed Dec 25, 2019 6:52 pm
by GarageSteve
Hi, I run an Indy garage and recently had a 64 plate Golf filling up both rear foot wells, and the door seals appeared wet, the water was draining through the door but then leaking through the seals where the speaker fits to the inside of the door, really random place to be leaking but being German they prob use the same idea ?
Re: Water leek
Posted: Fri Jan 03, 2020 10:50 pm
by Mikest
Hi both,
I've had the same problem for the last two years on the rear left door. My local BMW dealer had a look, altered the rear door hinges, but the problem remains. Whenever I open that door after a heavy rain water floods out onto the road.
Recently the same things happens with the tailgate, whenever I open that after a heavy rain.
It feels like there a problem with the door seals or.a drain that's got clogged, but I can't see anything obvious.
Regards
Mike
Re: Water leek
Posted: Sat Jan 04, 2020 9:01 am
by ssrfr03
Ok I have now discovered that the door seal around the door if full of water ? I put a small cut in it at the bottom to drain the water ,so how does this water get in to the seal ??
Re: Water leek
Posted: Mon Jan 06, 2020 7:54 am
by marti
ssrfr03 wrote: Sat Jan 04, 2020 9:01 am
Sounds to me like the seal has a split in it somewhere so when you close the door and squash the seal a split opens up and water gets inside the seal ??
