Air Suspension will NOT pump up
X5-D-Sport
Post by X5-D-Sport » Thu Jan 09, 2020 3:55 pm
Hello People,
I had an air leak in the near side rear air bag - UK - (rear suspension only is air inflated - front is springs)
I swapped BOTH air bags, nipped the air connections, all pumped up nicely & worked, + 100 yard drive.
The Air Suspn Inact warning remained on, so... I thought I'd be clever, cracked open the air line unions to each side (with fuse removed to allow the suspension to sink)
Nipped the unions up again, replaced fuse....
BUT
it will not pump up & the pump will NOT activate.
I drove another 100 yards & back, switched off vehicle, locked it & unlocked & re-started many times, but it will NOT activate the suspension pump...
I have read about driving it for 15 mins, or discoinnecting the battery etc, but there seem to arguments pro/against both of these..
Any ideas why or what the fix is please ?
Re: Air Suspension will NOT pump up
Post by henrym3 » Thu Jan 09, 2020 9:41 pm
Fuses, as you were in that area double check you didn’t disturb any of the connections to the pump
X5-D-Sport
Post by X5-D-Sport » Thu Jan 09, 2020 9:48 pm
It would appear that the vehicle has solved the issue on it's own some how...
I re-started it earlier this evening after it had been idle for 2 hrs, & as soon as the engine was started, it inflated the suspension & was working fine again...
The suspension error warning is still there, but I suspect it may clear itself if I'm lucky.
I did see a post that said--- walk away from it for a while & it will sort itself out... which may be the case.
Here's hoping the error message clears soon.
thanks to all.
Grant B
