Vacuum hose - where is it from?!
Posted: Sun Dec 05, 2021 12:39 pm
by coops
Found that a previous owner had half done a EGR delete which had involved bending the pipe to block it!
All done properly but in order to do this I had to remove the air pipe which goes down near it. When putting back together I found this - I’m sure it wasn’t there before. Any ideas where it goes?
- 93CB91BC-0152-431F-A85E-896C7B3AFF5A.jpeg (140.73 KiB) Viewed 8065 times
Posted: Sun Dec 05, 2021 12:54 pm
Has one end fallen off the vacuum reservoir (little round basket thing with a pipe on each end) on the off-side wing close to there? It’s the vacuum reservoir for the turbo.
Just trying to find some images to help you.
EDIT I think it’s 1b below?
- A1500E7A-0478-4411-8CA5-D188AB2CF47C.jpeg (95.25 KiB) Viewed 8061 times
Posted: Sun Dec 05, 2021 6:18 pm
by coops
I think 1b is exactly it! I’ll have a look in the morning.
Many thanks indeed. Where did you find the image?
Posted: Sun Dec 05, 2021 6:58 pm
Glad it might have helped. It was in an old file library from when I had my E53. Probably something I found a decade or more ago.
Posted: Mon Dec 06, 2021 7:03 am
by Alan Gunn
You might want to renew them while you are down there.
