Parking sensors sound
The beep sound for the pdc has stopped working.
I have had a diagnosis and there was no fault.
I have bought a new module and swapped and still nothing.
I have had the sensors tested and they all work fine I just don't have any sound.
I dont have the original head unit. I have a pioneer installed.
All was working fine until a week ago and now nothing.
Any ideas??
Any ideas??
I'm not sure.
Does pdc have a separate speaker?
If so where would it be located?
Reverse lights working ????.
Just a thought switch for them fail.
Yes. Reverse lights work. And sensors all.work it's just the beeper that's stopped. Not sure where the speakers are located to test them.
The PDC on the e70 uses the stereo speakers so you have 4 as far as Im aware.
All the music and warning tones still work.
So I assume there are separate speakers for the pdc?
Ive found a wiring diagram and it shows the wiring is all to the speakers.....page 6 in link below:
https://www.xoutpost.com/pdf/e70/05c1_E ... ontrol.pdf
Thank you very much ill have a look, see if I can figure it out.
