Fitting a Westfalia Detachable Towbar & Dedicated Electric
How-To articles ONLY go here.
wilkoturbo
Post by wilkoturbo » Mon Dec 19, 2011 8:51 am
Really ??? I'll check as I have a new caravan
bmw x5 le mans blue
B5tew
Post by B5tew » Mon Dec 19, 2011 5:52 pm
The fridge should work with 13 pin. I have never had a problem with mine working. On my old caravan I had an adaptor to go from the 13 pin on my car to the 12n and 12s on the caravan and it worked fine.
2015 Space grey 30d F15
wilkoturbo
Post by wilkoturbo » Mon Dec 19, 2011 7:05 pm
It's just someone said the pin that powers the fridge is missin ?!?!?
bmw x5 le mans blue
shadrack
Re: Fitting a Westfalia Detachable Towbar & Dedicated Electr
Post by shadrack » Mon Dec 19, 2011 7:22 pm
nice towbar write up shame i did mine 6 months ago p.s. B5tew i would probly not put a google map to my house on an open forum! :?
current: 2016 Vw Crafter
              2007 318d touring
              2008 Transit sport van
              1964 vw beach buggy
              1988 e30 325i convertible
bonerp
Post by bonerp » Mon Dec 19, 2011 8:52 pm
[quote=""wilkoturbo""]It's just someone said the pin that powers the fridge is missin ?!?!?[/quote]
mine powers the fridge
BMW X5 Le Mans Blue Exclusive 2006 Black nappa
Porsche 356 Speedster replica Condor Yellow https://sites.google.com/site/bonerp356/
B5tew
Post by B5tew » Tue Dec 20, 2011 11:28 am
[quote=""shadrack""]nice towbar write up shame i did mine 6 months ago p.s. B5tew i would probly not put a google map to my house on an open forum! :?[/quote]
i dont know why it puts that on there It only does it when I post from my Iphone
B5tew
Post by B5tew » Tue Dec 20, 2011 11:30 am
Oh by the way it will only power the fridge when the engine is running
wilkoturbo
Post by wilkoturbo » Tue Dec 20, 2011 4:32 pm
That's why thanks , iPhone setting geo tag on/off
bmw x5 le mans blue
mikem
Post by mikem » Fri Jan 20, 2012 11:25 pm
The Westfalia wiring kit doesn't have a functioning pin 10 which is for charging/fridge.
Some of the other manufacturers wiring kits do but cost more £150ish Vs £90.
Can anyone with a factory fitted OEM kit confirm wether pin 10 is present ?
gchristofi
Post by gchristofi » Sat Jan 21, 2012 11:50 am
What a great write up UrbanFlow ... makes me want to get a towbar AND A CARAVAN just to be able to use your excellent info............ :thumbsup:
DevonX5
Post by DevonX5 » Thu Feb 09, 2012 4:53 pm
Just got my towbar kit through the post and am using this as my guide to fit. Excellent "how to". Many thanks indeed. If only all "how to's" were the same :thumbsup:
jonnyivy
Post by jonnyivy » Sat Feb 25, 2012 5:25 pm
If I buy the designated 7 pin instead of the 13 pin wiring harness,.. will the connections in the boot area be the same ie. the white control box and the connecting plug ?
Virgin owner of X5 3.0 D 2003 ( getting to know her better now )(thinking of a long-term relationship now )( sadly  now divorced !! )( 4 years later...met the newer model and happy again )
UrbanFlow
Post by UrbanFlow » Mon Feb 27, 2012 12:38 pm
[quote=""DevonX5""]Just got my towbar kit through the post and am using this as my guide to fit. Excellent "how to". Many thanks indeed. If only all "how to's" were the same :thumbsup:[/quote]
Thanks for the comments. Was your fit successful?
Current Rides:
Previous Ride:
2003 Silver 3.0i Sport E53 X5
UrbanFlow
Post by UrbanFlow » Mon Feb 27, 2012 12:50 pm
[quote=""jonnyivy""]If I buy the designated 7 pin instead of the 13 pin wiring harness,.. will the connections in the boot area be the same ie. the white control box and the connecting plug ?[/quote]
No idea regarding the connections - but I would assume that they would be just plug and play if they are the Westfalia kit as they are what BMW supply and fit.
If you are going to the trouble of fitting it yourself I would suggest going for the 13 pin set up and using a 13-7pin adapter like I do (they cost less than a tenner from a decent towing shop or online). With just a 7 pin electrics system fitted you'll put off people with caravans when you come to sell the car. Just a thought.
Current Rides:
Previous Ride:
jonnyivy
Post by jonnyivy » Mon Feb 27, 2012 6:47 pm
Good suggestion,.. never thought of that,.. I have a caravan with both black and grey plugs but I've never used the grey one for charging the caravan and chilling the fridge. There's been a debate on here already about whether the fridge will work off this 13 pin system ??
