Page 2 of 6
Fitting a Westfalia Detachable Towbar & Dedicated Electric
Posted: Mon Dec 19, 2011 8:51 am
by wilkoturbo
Really ??? I'll check as I have a new caravan
Posted: Mon Dec 19, 2011 5:52 pm
by B5tew
The fridge should work with 13 pin. I have never had a problem with mine working. On my old caravan I had an adaptor to go from the 13 pin on my car to the 12n and 12s on the caravan and it worked fine.
Posted: Mon Dec 19, 2011 7:05 pm
by wilkoturbo
It's just someone said the pin that powers the fridge is missin ?!?!?
Re: Fitting a Westfalia Detachable Towbar & Dedicated Electr
Posted: Mon Dec 19, 2011 7:22 pm
by shadrack
nice towbar write up shame i did mine 6 months ago p.s. B5tew i would probly not put a google map to my house on an open forum! :?
Posted: Mon Dec 19, 2011 8:52 pm
by bonerp
[quote=""wilkoturbo""]It's just someone said the pin that powers the fridge is missin ?!?!?[/quote]
mine powers the fridge
Posted: Tue Dec 20, 2011 11:28 am
by B5tew
[quote=""shadrack""]nice towbar write up shame i did mine 6 months ago p.s. B5tew i would probly not put a google map to my house on an open forum! :?[/quote]
i dont know why it puts that on there It only does it when I post from my Iphone
Posted: Tue Dec 20, 2011 11:30 am
by B5tew
Oh by the way it will only power the fridge when the engine is running
Posted: Tue Dec 20, 2011 4:32 pm
by wilkoturbo
That's why thanks , iPhone setting geo tag on/off
Posted: Fri Jan 20, 2012 11:25 pm
by mikem
The Westfalia wiring kit doesn't have a functioning pin 10 which is for charging/fridge.
Some of the other manufacturers wiring kits do but cost more £150ish Vs £90.
Can anyone with a factory fitted OEM kit confirm wether pin 10 is present ?
Posted: Sat Jan 21, 2012 11:50 am
by gchristofi
What a great write up UrbanFlow ... makes me want to get a towbar AND A CARAVAN just to be able to use your excellent info............ :thumbsup:
Posted: Thu Feb 09, 2012 4:53 pm
by DevonX5
Just got my towbar kit through the post and am using this as my guide to fit. Excellent "how to". Many thanks indeed. If only all "how to's" were the same :thumbsup:
Posted: Sat Feb 25, 2012 5:25 pm
by jonnyivy
If I buy the designated 7 pin instead of the 13 pin wiring harness,.. will the connections in the boot area be the same ie. the white control box and the connecting plug ?
Posted: Mon Feb 27, 2012 12:38 pm
by UrbanFlow
[quote=""DevonX5""]Just got my towbar kit through the post and am using this as my guide to fit. Excellent "how to". Many thanks indeed. If only all "how to's" were the same :thumbsup:[/quote]
Thanks for the comments. Was your fit successful?
Posted: Mon Feb 27, 2012 12:50 pm
by UrbanFlow
[quote=""jonnyivy""]If I buy the designated 7 pin instead of the 13 pin wiring harness,.. will the connections in the boot area be the same ie. the white control box and the connecting plug ?[/quote]
No idea regarding the connections - but I would assume that they would be just plug and play if they are the Westfalia kit as they are what BMW supply and fit.
If you are going to the trouble of fitting it yourself I would suggest going for the 13 pin set up and using a 13-7pin adapter like I do (they cost less than a tenner from a decent towing shop or online). With just a 7 pin electrics system fitted you'll put off people with caravans when you come to sell the car. Just a thought.
Posted: Mon Feb 27, 2012 6:47 pm
by jonnyivy
Good suggestion,.. never thought of that,.. I have a caravan with both black and grey plugs but I've never used the grey one for charging the caravan and chilling the fridge. There's been a debate on here already about whether the fridge will work off this 13 pin system ??
