Faulty parking sensor
Rick
Post by Rick » Sat Aug 21, 2010 5:29 pm
Hi all,i have a problem with the parking sensors,when the engine is started wether i select Drive or Reverse the sensors bleep constantly without any obstacles in front or behind,i have to turn the alarm off using the parking button.Any will be much appreciated.
many Thanks Rick
2004 4.8is Le Mans Blue
Mods,Speaker upgrade to JL Audio C5 650 CSI Comps,Pioneer TS-WX77A subwoofer,Lazer Pro Park.
Pewters
Re: Faulty parking sensor
Post by Pewters » Sat Aug 21, 2010 5:54 pm
Put your ear right up close to every sensor and you should hear a clicking ...........obviously the one that qint clicking is the faulty one ;)
pvr
Post by pvr » Sat Aug 21, 2010 5:58 pm
And pray it is an accessible one ...
x555
Post by x555 » Sat Aug 21, 2010 6:07 pm
Fingers crossed for you it's one of the rears.
Mine have been playing up recently aswell constant tone some times and perfect at other times :evil: i'm guessing that it's moisture in one of them :roll: I did the click test the other day and they were all clicking :-? unlike before when i changed the front one and fixed them fine.......for a while at least :roll:
Rick
Post by Rick » Sat Aug 21, 2010 6:09 pm
Thanks for replies,as soon as ignition is switched on even without engine running the sensors are sounding constantly as if the x is parked right against something,its the same even if i am driving along.It is hard to pinpoint which sensor it is because os the constant noise :x
x555
Post by x555 » Sat Aug 21, 2010 6:14 pm
This may be a stupid question mate but are they all clean?? it doesn't take much for these flaming things to play up :roll:
Rick
Post by Rick » Sat Aug 21, 2010 6:16 pm
Yep all clean,im sure 1 sensor is shorting out but its difficult to find which 1 with the constant tone all the time
Cheers Rick :headbang:
pvr
Post by pvr » Sat Aug 21, 2010 7:25 pm
Close the door whilst listening outside?
Rick
Post by Rick » Sat Aug 21, 2010 9:24 pm
I think i have found which sensor is faulty,its in the front bumper nearside corner is it easy to remove ???
Thanks Rick
Sanj
Post by Sanj » Sat Aug 21, 2010 10:32 pm
Nope, bumper off jobbie BUT x555 has done How To for us on removing that front bumper. And the sensor should come in at £25 from eBay rather than the £80ish from the $tealers!
And it is different to all the others (front corner ones are different to the other six). These two are angled...
x555
Post by x555 » Sun Aug 22, 2010 9:37 am
[quote=""Rick""]I think i have found which sensor is faulty,its in the front bumper nearside corner is it easy to remove ???
Thanks Rick[/quote]
As Sanj says thats a bumper off job :roll: that happens to be the very one that i replaced on mine a while back due to water/moisture gettin in.The bumper has to come off as it is encased in the steel of the bumper and you can't get your hand up to it.
Rick
Post by Rick » Sun Aug 22, 2010 11:34 am
[quote=""x555""][quote=""Rick""]I think i have found which sensor is faulty,its in the front bumper nearside corner is it easy to remove ???
Thanks Rick[/quote]
As Sanj says thats a bumper off job :roll: that happens to be the very one that i replaced on mine a while back due to water/moisture gettin in.The bumper has to come off as it is encased in the steel of the bumper and you can't get your hand up to it.[/quote]
Have looked on ebay but can only find straight sensors and not the angled ones for the corners,any ideas where i can get 1,also i cant find the part number.
Cheers Rick
x555
Post by x555 » Sun Aug 22, 2010 11:47 am
Here ya go.....no 12 http://www.realoem.com/bmw/showparts.do ... g=66&fg=05
Just washed mine and thought i would look at the pdc after this thread and got a constant tone but all sensors were ticking :headbang: one of the fronts did seem a little weaker thab the others so it could be that sucker :roll:
x555
Post by x555 » Sun Aug 22, 2010 11:55 am
Here's the type your after http://cgi.ebay.co.uk/BMW-ORIGINAL-PDC- ... arParts_SM
but you would have to email the seller to check the code.
It doesn't necessarily have to be the same code to work AFAIK.Mine wasn't the same part no when i replaced mine but don't quote me on that as i wouldn't want you to get the wrong one.
Pewters
Post by Pewters » Sun Aug 22, 2010 3:11 pm
Mine have been faulty for some time but its getting to me now...............i'll get Sanj on them soon ;)
