40 pin quadlock connection
Hi,
I have a 2003 X5 with MID radio and a cassette player. Does my car have a 40 pin quadlock connection?
Re: 40 pin quadlock connection
Probably, but you'll need to either know the part number of the radio or just take it out and have a look to be sure.
Hi,
I took out the radio display, but where is the 40 pin quadlock plugged in?
Could be in the boot by the battery.
There are a few plugs around the battery area, but how do I know which one it is.
How do you insert a picture , I can then show you the pictues.
[quote=""mas123""]How do you insert a picture , I can then show you the pictues.[/quote]
Try this link here..... viewtopic.php?f=28&t=400
In the boot, this is where it is (circled):
Hi,
Thanks for the picture illustration. I don't have that in my boot does that mean the wires going to my cassette player in the front are ones?
hi
i learnt from the maestro himself "sanj" that on mine the quadlock is in the front . follow the leads that directly plug into the units until they meet another plug "quadlock"
2002 3.0d black sport auto, now with added mods!!!re-map,chrome clock rings, folding mirrors,wind deflectors,angel eye led hid's,19"sport wheels,reverse cam,ps2 media+hdd,dvd headrests,alpine v12 amp+sub,+alarm chirp !!!!
Hi,
I followed the wires in the front and there is a plug going to my cassette player. It has two blue strips and four round holes. Is that it?
Follow those two down into the dash it should be where the leads from the head unit and cassette meet
The quadlock connector plugs directly into the radio, left hand side looking from the front. The radio is located above the MID/IRIS for split systems, or in the boot for Nav systems.
I found it, it was plugged into the cassette player. Does anyone know the wire connections?
40 pin quadlock on the face of the plug:
There is a 12 pin white plug going to it - is that the steering controls?
There is a black plug 12 pin- ?
There is a block of 16 pins which are the speaker wires (8), power supply and remote, but not sure what the other 6 wires are for.
Thanks.
Thanks.
