Sourcing E53 Folding Mirror switch V4NCST7C4ACX
Posted: Wed Aug 24, 2011 10:03 pm
Thanks to the E53 folding mirror D.I.Y. posted by Sanj I have been able to fix my E53 electric folding mirrors.
Many of us who have these items on our cars will know that these mirrors often fail. There can be various reasons for this but the most common issue seems to be a failure of the microswitch that sits inside the mirror housing and contacts with the pivoting/rotating part of the folding mirror.
For those with a car so equipped it would be fair to assume that there is a high possibility of you encountering a microswitch failure at some point.
BMW do not currently list the microswitch as a repair part for the mirror housing mechanism. Thus anyone who has a failure currently has a number of limited options.
1) Do nothing.
2) Try to fix it yourself with the potential for mixed results
3) Replace, (or cause to be replaced), the entire mirror unit, (at a cost of many hundreds new from your chosen dealer).
4) As above but sourcing a salvage item in the hope that it is serviceable.
Thanks to information provided by others on here & on xoutpost I have made enquiries into the sourcing of the microswitch as a stand alone item.
Currently & to my knowledge, nobody in the UK or R.O.W. is selling these switches to retail customers.
SAIA Burgess who make the switch only supply the item when bought as a minimum order totalling 400 units.
As a result I have been in contact with a U.K. based distributor for SAIA Burgess. I have made a provisional enquiry in regards to sourcing lower quantity numbers of the switch. I have told the distributor/seller of the desire to source the item & that the item is allegedly a common failure item on the E53 with this option fitted.
The distributor I am in contact with is considering ordering a batch of 400 units with a view to selling them to end customers.
I do not have any details of pricing or availability at this early stage, however, I expect that retail pricing is likely to make the purchase of a new switch far more attractive than buying entire replacement mirror units.
If these can be sourced separately then I will certainly buy at least a couple as I know that this could save me hundreds in event I have to otherwise replace an entire mirror housing.
With this in mind I am keen to ascertain if others would be interested in purchasing these as a "just in case" part for use in future if so required.
Early days & all very much provisional. I will still need to confirm compatibility & maybe see a sample to compare &/or look at any wiring issues.
In the meantime it might be useful if folk who may be interested in buying these could express their provisional interest here.
1) Do nothing.
