Aux in socket rear of centre console
Posted: Tue Dec 06, 2011 9:20 am
by bonerp
Am I right in thinking I should be able to plug my phone into this using a normal audio male/male connector and play the tunes through the TV AV option?
Mine doesn't! Just get lots of interferance and no sound.
Re: Aux in socket rear of centre console
Posted: Tue Dec 06, 2011 9:29 am
by fenj66
i tried this too and got same result as you or at best an awful mono sound.
i think this socket is more for a video signal which might be stronger.
but you can buy for £35ish a stereo aux in lead from bmw which will work well with your method of replaying music. thats what i did to connect my ipod to the cars sound system.
it plugs into the wiring loom at rear of the obc.
Posted: Tue Dec 06, 2011 12:37 pm
by bonerp
wheres the OBC?
thanks for info I'll pop down later - I take it the gizmo just connects via an audio lead?
Posted: Tue Dec 06, 2011 12:50 pm
by fenj66
obc = on board computer. the big widescreen tv thingy in the centre of the dash.
yes, the bmw aux lead will just connect into an empty plug on the loom at the rear of it. but check with your dealer first just to be sure.
Posted: Tue Dec 06, 2011 12:53 pm
by bonerp
ah yes of course that big screen
Thanks for your help i'll pop into BMW later.
Posted: Tue Dec 06, 2011 12:59 pm
by bonerp
one more question - does this replace the cd changer? BMW werent 100% sure. The IPOD kit does apparantly.
Posted: Tue Dec 06, 2011 1:39 pm
by fenj66
the aux in lead isnt an ipod specific lead just a generic headphone style jack output lead.
it wont affect your cd player.
Posted: Tue Dec 06, 2011 1:50 pm
by bonerp
ok thanks again - theres a few online that appear to replace the CD changer so the BMW kit looks better of the lot. BMW said about £57 (plus vat I guess)
Posted: Fri Dec 09, 2011 9:57 am
by bonerp
Can someone kindly tell me how does the OBC come out?
Have just bought this from BMW - £57 for effectively 3 wires with a plastic connector on one end and aux socket on t'other. Disgusting. I was expecting something a little more attractive too - its a cheap metal plate screwed into a hole I need to drill in the glove!
edit: hmmm just seen an install where the socket had been taken off the plate and screwed into a hole drilled in the cigar tray. Looks like a good place to run it and the phone can then rest in the ashtry.
Posted: Fri Dec 09, 2011 10:18 am
by Phil D
It's really easy.
The plastic surround needs unclipping from the obc. That the reveals the torx screws that need undoing.
Slide the obc out - job done
Posted: Fri Dec 09, 2011 10:34 am
by bonerp
great thanks Phil D
Posted: Fri Dec 09, 2011 11:33 am
by Ubatoid
Any chance you could post up a picture of the lead could you ? It sounds suspiciously like one I have for a Renault magnum......( don't ask)
Posted: Fri Dec 09, 2011 11:34 am
by bonerp
pm me your email and I'll send on the instructions
Posted: Fri Dec 09, 2011 12:01 pm
by x555
If you haven't already done it mate there are a few pics on here that may help with the obc
viewtopic.php?f=10&t=3163
EDIT : Sorry fella here....
viewtopic.php?f=22&t=2273&p=24131&hilit=ribbon+cable#p24131
Posted: Fri Dec 09, 2011 7:17 pm
by bonerp
bmw charge 1.5 hrs to do this...took 15 mins.
