Oil
wilkoturbo
Oil
Post by wilkoturbo » Mon Jan 23, 2012 12:31 pm
Hi all should the oil on my dip stick be all the way to the top , is this wrong or damaging the engine
Many thaks Paul
3.0d
bmw x5 le mans blue
Smeeagain
Re: Oil
Post by Smeeagain » Mon Jan 23, 2012 1:48 pm
Oil, in any vehicle, should only be filled to the maximum mark indicated. Overfill is just as bad as underfill but in different ways but to put simply f it is above the maximum then it is not doing the engine/componentry any good. The maximum mark is there for a reason !
Sherwood
Re: Oil
Post by Sherwood » Mon Jan 23, 2012 1:51 pm
Make sure you have run the engine, removed the dip stick, wiped it, re-inserted it in the engine, removed it - before you read it! ;)
BMW E53 2003 X5 3.0D
Re: Oil
Post by X5Sport » Mon Jan 23, 2012 2:23 pm
As above, but also wait just a few mins (5 will do) for the (warmed) oil to drain back to the sump, and check it on level ground. Part of my drive is sloped slightly and makes a difference to the reading!
If it's still way over the mark, then you can get oil removers that go down the dipstick hole and you can then suck a bit out. Saves messing about under the car :)
dirtymonkey29
Oil
Post by dirtymonkey29 » Mon Jan 23, 2012 3:01 pm
[quote=""X5Sport""]
If it's still way over the mark, then you can get oil removers that go down the dipstick hole and you can then suck a bit out. Saves messing about under the car :)[/quote]
I have one of them (pella500) makes oil changes really easy
jaynana
Re: Oil
Post by jaynana » Mon Jan 23, 2012 3:06 pm
[quote=""smeeagain""]Oil, in any vehicle, should only be filled to the maximum mark indicated. Overfill is just as bad as underfill but in different ways but to put simply f it is above the maximum then it is not doing the engine/componentry any good. The maximum mark is there for a reason ![/quote]
just typed the question into google.. and yahoo answered :rofl:
http://answers.yahoo.com/question/index ... 218AADdI3x
wilkoturbo
Oil
Post by wilkoturbo » Mon Jan 23, 2012 4:04 pm
When I finish work I will check I hope I've not done any damage :(
bmw x5 le mans blue
Re: Oil
Post by X5Sport » Mon Jan 23, 2012 4:08 pm
Unless you were also seeing a lot of blue smoke I would think it's unlikely. But get any overfill out as soon as you can is definitely a course of action to take.
It's not unusual to see a little over the max mark, and usually with no ill effects at all.
See what it looks like when all is wiped off and settled and rechecked. You'll be fine :)
wilkoturbo
Oil
Post by wilkoturbo » Mon Jan 23, 2012 6:09 pm
I do get smoke on start up !!!!
bmw x5 le mans blue
Re: Oil
Post by X5Sport » Mon Jan 23, 2012 6:59 pm
That's normal for most diesel owners - if you're laying a smoke screen that's different unless your other name is 'Leadfoot'.. :D
Rusty
Oil
Post by Rusty » Mon Jan 23, 2012 8:36 pm
[quote=""X5Sport""]That's normal for most diesel owners - if you're laying a smoke screen that's different unless your other name is 'Leadfoot'.. :D[/quote]
That'll be my name you are calling then, bloody great on the motorway at night, covert mode, ish
Runabout - E92 3 Series Coupe
wilkoturbo
Oil
Post by wilkoturbo » Sat Mar 24, 2012 8:32 pm
23 of jan oil light came on filled up now oil lights on again !!!!! There is a very very little damp spot underneath but NOT on the floor any ideas where it's going !!? :(
bmw x5 le mans blue
Re: Oil
Post by X5Sport » Sat Mar 24, 2012 8:41 pm
How far have you driven since then? These engines do use oil. I think the BMW spec for the M57 diesel engine allows for about 0.5 litre/1,000 miles. Mine certainly used oil at that sort of rate when new but the rate slowed as the miles went on, but it always burned some oil between services. I expected that at some point the 'burn rate' would eventually climb again through normal wear.
The current N57S engine doesn't seem to use any at all so far.
wilkoturbo
Oil
Post by wilkoturbo » Sat Mar 24, 2012 8:47 pm
Not loads getting to work 120 nipping around town 30 maybe ? Just the lights on !
bmw x5 le mans blue
Re: Oil
Post by X5Sport » Sat Mar 24, 2012 8:52 pm
What's the dipstick showing? I had a bad sensor replaced within 3 months of getting the car. The BMW Assistance Driver who came out said it was a 'known problem' with both the level and pressure sensors. Used to scare the cr@p out of me when the 'Stop! Low Oil Pressure!' warning came on. :o
I think the bottom to top mark is 1 litre so if you've only done 150 miles and lost that much oil and not laying a clear smoke trail then you have a leak - although your description of the vehicle and drive state belies that view. :scratchhead:
