BMW Multi Tool
Posted: Thu Feb 16, 2012 8:42 am
BMW Multi Tool User Manual
New BMW Multi tool V1.2 can be used to:
1. Read / Write EEPROM, Save / Load File;
2. Read / Write Odometer:
BMW multi tool read and change the mileage stored in CAS system, but NOT the mileage in instrument panel.
So if you want to change the mileage values in instrument, you should change it in CAS system first. And modify the mileage in instrument manually.
3. Synchronization Codes:
- CAS3 code-DME, CAS3code-EGS: Read and write DME and EGS code stored in CAS3 system.
- Synchronize DME and CAS— this will be useful while prepare dealer key or any other operation which cause can’t start the engine.
- Synchronize CAS and ELV — this can help clear wheel errors
4. Key Learn Function:
Get/Save/Load Key Info; Make Dealer Key; Add Key; Enable/Disable Key; Clear DTC; Clear Shadow.
BMW Multi Tool protocols:
