iPhone 4 and blue tooth
I was bored waiting for the wife, so just started playing with the BT so far I have found the car and the code.
The problem is, is then says connected, but a few seconds later says on the iPhone not connected.
Any body give any info.
Re: iPhone 4 and blue tooth
Did the system go through the pairing process on the navigation screen?
I don't no I did it through intravee, is this the wrong way.
Not sure about doing it through intravee but may be worth pairing through the OE system and it may then just connect through intravee each time.
Ok I will check doing it that way, what do I do though.
It's something like press and hold the button in the armrest for 3 seconds then whilst it's still pressed turn key to ignition 1 and continue to hold for another 3 seconds then when you release the screen should show as pairing and you then put the code into the phone. Once paired turn ignition off and should be sorted.
Ok ill check and have a play later, want really bothered as I was just messing while bored.
Cheers though
Cheers though
Try deleting all text messages from our phone, with some versions of the Bluetooth ULF they can cause this type of behaviour.
Ok cheers
Will try that, the other post just seems to do the same connects then says discounted within a second or 2.
