Tyre Valves - where to buy?
Posted: Mon May 21, 2012 3:12 pm
by dark_stranger
I need to replace my tyre values and BMW have quoted £15 per tyre for rubber values and awaiting a price for the chrome values. Does anyone know where I can buy the metal value, hopefully cheaper than via BMW?
I would prefer to replace, like for like, so what the chrome.
Re: Tyre Valves - where to buy?
Posted: Mon May 21, 2012 3:48 pm
I take it you mean tyre valves? I don't think the BMW ones are anything special so you should be able to get them from any decent tyre place. If it's just the valve caps, even Halfrauds sell them. Or you could try the usual eBay look see..
Re: Tyre Values - where to buy?
Posted: Mon May 21, 2012 4:09 pm
by dark_stranger
lol, yes valves.
Posted: Mon May 21, 2012 4:18 pm
by LincsX5
The valves are cheap, the cost comes with removing the tyres to replace the valves, then fitting and balancing after. Why do they need replacing? Are they damaged or leaking? If they are leaking from the core then just replace the core so you can keep your metal valves. If they do need replacing try some Motorsport spares shops such as Merlin.
Posted: Mon May 21, 2012 10:14 pm
by dark_stranger
The tyres have pressure sensors as due to having 1 tyre larger (spare) than the other 3, the warning messages keep going off. What do i need to buy? Can you buy just the metal bit visible outside of the wheel?
Posted: Mon May 21, 2012 10:15 pm
by dark_stranger
The valves are in a bad condition, one lets out more air the i can put in, so want to replace them.
Posted: Tue May 22, 2012 8:08 am
by LincsX5
You can have the valves replaced at any tyre fitters, worth having a ring round for prices. As for what you want to replace them with, it's upto you. Standard rubber valves, rubber valves with chrome sleeves, metal screw in valves or screw in flush valves that you use an adaptor to check/pump up your tyres. What ever you use the tyres will have to come off regardless.
I've had a car with metal valves and not had any issues with them. I've also had a car with the chrome covers.......they got nicked. Have a google and see what you like.
Posted: Tue May 22, 2012 11:26 am
by dark_stranger
To save any messing about I have booked the car into BMW. They advise that due to having the pressue sensors, its best to go for the metal valves (true or not?) but, its what I wanted. They have priced it at £116 to replace all 4. Removing tyres, fitting valves, refitting tyres & balancing.
Posted: Tue May 22, 2012 12:16 pm
by dirtymonkey29
£29 a wheel!!! Or £23.20 if spare is included. Seems expensive to me. I'd just get the dodgy one replaced, who really looks at tyre valves anyway, apart from thiefs that pinch your nice valve caps.
Posted: Tue May 22, 2012 12:52 pm
by dark_stranger
All 4 values are in pretty bad condition and therefore makes sense to get them all done at the same time.
