Scanner programming. (Tyre pressure monitoring)
Posted: Tue Jun 26, 2012 1:39 pm
I'm not a frequent vistor these days but i would appreciate help from those in the know if possible.
I finally got my techie friend, me, my car and scanner in the same place to switch off the audio/visual for the tyre pressure monitoring system. Easy when you know how
A simple uncheck in the appropriate box immediately flashed up self levelling suspension inactive? though that wasn't touched. A simple on/off with the ignition cleared that message and the only adjustment actually made was the one desired for the tyre pressure monitoring system. Is it normal for the suspension warning to flag i wondered? The car did not advise of this again and the desired switch off required seems to be OK, no gongs or visual display now, The silence at engine switch off is wonderful
