webasto question (again :))
Posted: Sat Aug 11, 2012 3:32 pm
by jaynana
those who have telestart or remote start sorted out on the webastos (ie, switching it on by giving +12v to pin 1), if you give +12v to pin 1 on a day like today (23c outside), does the webasto run?
basically, does the switch on method of +12v to pin 1 seem to ignore the outside temperature checks?
thx
j
Re: webasto question (again :))
Posted: Sat Aug 11, 2012 5:06 pm
by malc1950
Yes mine will fire up and run regardless if i put a live feed to pin 1 on the wabasto
Posted: Sat Aug 11, 2012 7:56 pm
by wilkoturbo
Wish my did think its my battery
Posted: Sun Aug 12, 2012 7:32 am
by jaynana
thanks guys,
j
Posted: Wed Aug 15, 2012 5:58 pm
by X MAN
[quote="jaynana"]
thx
j
Tried mine yesterday, 24c outside and it fired up until i switched it off 15 mins later . 2 years ago i fitted a Telestart T90 module / antenna / remote and programmed the aux heating on the OBD using BMW scanner 1.4.0 and always assumed it only worked with the outside temperature below 5c .
Posted: Wed Aug 15, 2012 9:37 pm
by jaynana
thanks, it just confirms that the second method of firing up the webasto - that is +12v to pin 1 ignores the temperature checks (plus possibly more).
the primary method of firing up which is a k-bus command does the temperature check plus more..
so what you thought is not exactly wrong..
j
