Angel eyes flashing
Posted: Wed Nov 07, 2012 9:46 pm
by malc1950
Fitted new LED angle eye bulbs on Monday but have noticed tonight when i was parked up to the garage door in the dark that when i turned on the ignition with the lights off the angle eyes were flashing across and back, i had a Volvo truck that did the same the lights flashed while it did its check, is this what my X is doing ?
Re: Angel eyes flashing
Posted: Wed Nov 07, 2012 9:48 pm
by shadrack
my x5 has done this before, but not every time i dont think, but im sure its normal and that as long as there ok afterwards its ok
Posted: Wed Nov 07, 2012 9:59 pm
by malc1950
Hi Shadrack as you will know the FH goes through a similar light check, i am thinking that's what the X is doing, apart from that no problems with electrics,
Posted: Wed Nov 07, 2012 10:11 pm
by pvr
Normal with LEDs yes.
Posted: Wed Nov 07, 2012 10:22 pm
by malc1950
Thanks PVR, lights check thought it was,
Posted: Thu Nov 08, 2012 12:08 am
by Raj
Totally normal as it is self testing and personally think it looks cool.
My number plate ones do the same.
Posted: Thu Nov 08, 2012 7:48 pm
by Horizon
Hi Malc,
Thats normal for LED's the cold test pulses to check the bulbs is enough to light up LED's but not the normal halogens, havnt noticed mine as have them on DRL's coded it with the scanner.
I may take the code out and check them, Ive seen them on youtube showing the flashes. I think it looks cool as well, you can turn off the cold pulse test to the LED markers on the scanner if you want.
Posted: Thu Nov 08, 2012 9:09 pm
by malc1950
Turn them off not if they look cool Pete !!! lol
