Starter Motor
Posted: Mon Nov 26, 2012 9:29 pm
I have put a couple of posts up previously about the current drain I appear to have on my 2002 4.4i X5. I can fully charge the battery, use the car for a day then come to it the following day and the battery is completely flat, yet I can also go a week and it be fine.
I have replaced the fsu as I discovered this was faulty and causing the fan to run even when the car was off. however the problem with the current drain is still there.
I have search various forums and read about the starter motors failing and pulling a huge current which unless driven miles the alternator can't replace.
On starting the car tonight with a charged battery it seemed to crank quite slowly and laboured. could this
be a sign of a starter motor issue.
Also is the starter motor issue known on the 4.4i, as all the forum posts I can see dont state an engine type.
Andy
Andy
