Check Brake Linings
Posted: Mon Dec 10, 2012 11:59 am
by dark_stranger
Guys, started getting the message "check brake linings" and believe it relates to a worn brake sensor. I changed my front pads\discs in the summer and know the rear ones need doing, so guess this is why the message has appeared.
I know I will need discs, pads and i guess a new sensor, but will i need anything for the handbreak, such as shoes, cable?
Check Brake Linings
Posted: Mon Dec 10, 2012 1:30 pm
by kkodal78
the only way to know if you really need brake shoes for E-brake is to take the disc off to see it. but if you are already changing the pads and discs in the rear, i personally would pay extra £20-£30 to get the shoes and replace them as well. this way you don't have to worry about it going low anytime soon.
Re: Check Brake Linings
Posted: Mon Dec 10, 2012 1:42 pm
by pvr
Agreed, and the hand brake generally is an MOT failure item as they are so infrequently used on an X5.
Posted: Mon Dec 10, 2012 4:53 pm
by dark_stranger
[quote="kkodal78"]
Agree. does make sense to do it all at the same time.
Posted: Sat Nov 16, 2013 9:17 am
by jaynana
damn! i got this message yesterday. a bit intermittent yet..
re. checking the sensors - so its the nearside front and offside rear to check, right..
its frosted out there!
