Page 1 of 2
25w Cree LED Angel Eye Units
Posted: Fri Jan 11, 2013 12:39 pm
by dark_stranger
I have just ordered some of the above units and will post a review once they arrive.
Re: 25w Cree LED Angel Eye Units
Posted: Wed Jan 16, 2013 1:35 pm
by dark_stranger
The LED's have arrived and I'm at bloody work. Will fit them tonight and let you guys now what they look like, espically in the daytime.
Posted: Wed Jan 16, 2013 2:52 pm
by Raj
[quote="dark_stranger"]
Very very interested and in the sort of heat dissipation from the back of them.
Posted: Thu Jan 17, 2013 10:09 pm
by dark_stranger
LED's fitted and will upload pics soon, but as we'll as the LED units it has 2 metal things, ballasts? But how/where are you meant to attach them as I guess you can't have them just hanging there.
Posted: Thu Jan 17, 2013 11:02 pm
by Raj
Ah ok. They have a ballast attached. Similar setup to the E46 angel eye kits I've fitted. The ballast can just sit inside the headlight unit next to the bulb. There is space enough in there. Just interested in the brightness now as I'm sold on a set.
Posted: Fri Jan 18, 2013 12:12 pm
by dark_stranger
I havent been at home during daylight hours since getting them, so have been unable to take pictures, but will do so over the weekend.
I was just concerned that if the ballasts where touching the actual LED unit, the heat from the LED heatsink would transfer onto the ballast and cause issues.
Posted: Sat Jan 19, 2013 12:03 am
by Raj
See your point. Just try and tuck it down into the headlight unit away from the heatsink.
So are they a lot brighter?
Posted: Sat Jan 19, 2013 2:12 pm
by storminmike
[quote="Raj"]
This sound a lot like the many page thread about "do 55w HID Ballasts make brighter lights"
My (normal aftermarket from HIDS direct) LED ones I have are a lot better than the yellow standard....will we ever find out if the Crees take us to the next level.....i'm intrigued
Posted: Thu Jan 24, 2013 11:59 pm
by Raj
Sooooooooo.............????????????
Posted: Fri Jan 25, 2013 8:29 am
by Denis O
Yes, the world needs to know.......well at least the Xdrivers bit of it.
Posted: Fri Jan 25, 2013 1:54 pm
by dark_stranger
ok, ok, here are the pics, unfortunately as both original angel eye bulbs have gone, I cant give you a comparison picture. But will try and get a bulb and some point.
I only wanted these for day running at if you are normal car level (2nd pic) they ae brightish. Maybe someone can post a daytime pic of their 3w, 5w, etc. LED's to compare.
Posted: Fri Jan 25, 2013 7:47 pm
by jaynana
they don't open
Posted: Fri Jan 25, 2013 8:51 pm
by dark_stranger
[quote="jaynana"]
they don't open
What doesn't open?
Posted: Fri Jan 25, 2013 10:41 pm
by Raj
Hmm. Can't be sure they are that much brighter. Really need a side by side shot with one 'standard' led replacement bulb unit in one headlight to the 25w jobbies in the other.
Posted: Sat Jan 26, 2013 9:43 am
From that photo they look about as bright as the HIDS4U ones I had on my E53. Fine in lower light levels but not much in bright daylight.
R
