Page 1 of 2
@rse........
Posted: Fri Jan 25, 2013 7:07 pm
by Steamyrotter
After a lengthy but slow trip last night in own to -5degrees C car started vibrating and losing power. >:(
Thought may be frozen MAF or similar
Looked this morning and had "rough Idle" and "fuel rail boost pressure" faults!!
Car still rough. Moved it (after jump starting as left ignition on for too long whilst diagnosing.) and noticed patch of fluid on ground.
Looking underneath it was dripping from the inspection hatch in the bottom cover... Though Oh Hell the gearbox seal & pump had gone..
Moved car and had a sniff to find it's diesel so thinking its either a split hose dropping rail pressure, a failed return line or a nadged injector....
Will be ripping the bottom and top covers off this weekend and having a butchers..
Not a happy bunny
Re: @rse........
Posted: Fri Jan 25, 2013 7:56 pm
by jaynana
all the best mate..
have fun, doing that in -5c
Re: @rse........
Posted: Fri Jan 25, 2013 8:50 pm
by Sanj
Bollox - what a PITA. >:(
Know you're more than capable but not nice in this weather. Hope it's a quick diagnosis and cheap fix buddy.
Fingers are crossed for you!
Re: @rse........
Posted: Fri Jan 25, 2013 10:46 pm
by Raj
Echo Sanj above. That's not good news at this current time of year. Hope it's not too costly and troublesome to resolve.
Re: @rse........
Posted: Sat Jan 26, 2013 4:03 pm
by pvr
Why is it this always happens at these type of weather conditions ...
Good luck.
Re: @rse........
Posted: Sun Jan 27, 2013 7:11 pm
by Steamyrotter
Well think i've sussed it..
After a sunny start and progressing through showers, wind and hail...
Appears to have been 2 separate coincidental issues..
Vibration / noise due to one bolt on the torque convertor working loose and catching on a fillet on the rear of engine.. Tightened and thats gone now..
Diesel was coming from a loose connection on the plastic feed pipe where it connects before it supplies the main fuel rail (hard to describe but there is a block under the inlet manifold with the feed, return and connection to the main fuel rail) Changed the jubilee clip and seems to have solved that.
Onward to the next issue.......
Re: @rse........
Posted: Sun Jan 27, 2013 7:38 pm
by Sanj
[quote="Steamyrotter"]Onward to the next issue.......
Think you've had your fair share and need a break now! Well done - thankfully no cost really.
Well worth the look rather than 'booking-it-in'.
So, we seeing you at the Meet?
Re: @rse........
Posted: Sun Jan 27, 2013 7:50 pm
by ITBarbie
Well done. I'm glad you got to the bottom of it
Re: @rse........
Posted: Mon Jan 28, 2013 10:43 am
by fenj66
how did you manage to tighten up a t/c bolt? did you have to remove the gearbox?
Re: @rse........
Posted: Mon Jan 28, 2013 11:00 am
by Rusty
Nice work.
A real PITA but satisfying when you can fix it yourself. Well done.
Re: @rse........
Posted: Mon Jan 28, 2013 11:02 am
by Don Coffey
Well done that man! Really satisfying conclusion to what could have turned out to be a major issue.
Don
Re: @rse........
Posted: Mon Jan 28, 2013 1:11 pm
by Steamyrotter
[quote="fenj66"]
There are 3 bolts holding the torque convertor to the flex plate.
They are accessed by removing the rubber bung in the flywheel cover plate on the drivers side.
(bolts are item 5 of :-
http://realoem.com/bmw/showparts.do?mod ... g=11&fg=20
plate is item 9 of :-
http://realoem.com/bmw/showparts.do?mod ... g=11&fg=10)
Needs to be done from underneath and is a pain in the neck..
Re: @rse........
Posted: Mon Jan 28, 2013 3:10 pm
by jaynana
:thumbup:
u have a covered garage i hope - those components couldn't have been too friendly with rain!
Re: @rse........
Posted: Mon Jan 28, 2013 8:13 pm
by Steamyrotter
Front half of the car under a car port...
Bit breezy and when it hailed it was bouncing along the bottom and hitting me on the head... :'(
Re: @rse........
Posted: Mon Jan 28, 2013 8:56 pm
Not sure if that counts as dedication...or desperation.....but well done either way..
