heated front seats retro fit
Posted: Sun Feb 03, 2013 11:34 am
by lezmtaylor
I am going to fit a pair of Waeco MSH 200 retro fit heated seat kits to my E53 (kit cost £120).
I know I am having to remove the front seats.
Which  number airbag  fuse/fuses will I need to remove from the glovebox fuse box before disconnecting the harness?
Have almost finished fitting the dash cam and am taking the power source from the overhead light unit adjacent to the interior mirror, saves routing the power cable all the way around the windscreen, down the pillar and through the dash, will fit a mini  on/off switch (ordered) to the interior mirror cover to save battery drain when not in use, and to save Sanj the time will take a few photos to show the install.
But need the airbag fuse info urgent, job due to start this afternoon.
Re: heated front seats retro fit
Posted: Sun Feb 03, 2013 11:37 am
Don't know which fuse, but if you fully dis the battery and touch both cables together that should discharge any residual charges on the vehicle.
Posted: Sun Feb 03, 2013 12:18 pm
by Sanj
Airbag and Side Airbag  44
If you do it without starting the car up the light should not come on the dash.
I'll get this in now then:
:worthless:
Posted: Sun Feb 03, 2013 1:16 pm
by lezmtaylor
Have lpg, so am not going down the battery disconnect road (lpg tank out).
And thanks Sang and'' Bolo with the X pronounced'' re photos.
Posted: Sun Feb 03, 2013 3:34 pm
by Sanj
Double check Lez - you have the pre-facelift and I've read that from my facelift.
Posted: Sun Feb 03, 2013 3:38 pm
by Raj
E53 is like E46 so car doesn't self test with the keys out so just disconnect the module under the seat. I did this last night with my drivers seat.
Just don't switch ignition on when module disconnected.
Posted: Mon Feb 04, 2013 4:09 pm
by lezmtaylor
Cheers Sanj and Raj
