Bluetooth pass code
Posted: Mon Nov 01, 2010 4:23 pm
by Buster
Recently purchased an X5 which has bluetooth but I don't have the pass code for pairing it with my phone. Spoke to the dealer and apparently they don't have it and will need to hook it up to their diagnostic system to obtain it
Is there any other way of finding out what the pass code is?
Re: Bluetooth pass code
Posted: Mon Nov 01, 2010 4:50 pm
by dwgwyther
Hi you will find it on the Bluetooth central unit in left rear boot area (underneath CD changer). hope that helps. it should be 4 digits.
Darren
Posted: Mon Nov 01, 2010 7:27 pm
by Buster
Got it, thanks. All connected up and tested, works perfect.
Posted: Mon Nov 01, 2010 8:18 pm
by pvr
And saved you quite a bit
Posted: Tue Nov 09, 2010 6:51 pm
by Smeeagain
Hi - hoping someone can help - i ahve the same issue with not havign the ccode but I cannot find the unti to get the code from. There is a silver box lyign at an angle of 45 degrees below the cd unit - is that it ? If so there is a number but appears to have the code obscured by various mounting brackets which i cant see how to release (will try and psot a pic at the weekend)
smee
Posted: Tue Nov 09, 2010 7:49 pm
by x555
That's the one
it's the bluetooth module and iirc my code was hidden behind the bracket
just undo it and then there should be a four digit code
Posted: Wed Nov 10, 2010 1:59 pm
by x555
Just in case it helps here's what it looks like....
and this is where the code is
edit... re done pics as they were lost with me organizing my photobuket accout
Posted: Thu Nov 11, 2010 11:38 am
by gchristofi
[quote=""smeeagain""]Hi - hoping someone can help - i ahve the same issue with not havign the ccode but I cannot find the unti to get the code from. There is a silver box lyign at an angle of 45 degrees below the cd unit - is that it ? If so there is a number but appears to have the code obscured by various mounting brackets which i cant see how to release (will try and psot a pic at the weekend)
smee[/quote]
Yes, I remember having the same problem when I got my car. You have to remove the unit to see the number. Better than paying a stealer though!
