bmw 140 scanner cant get it working
Posted: Mon Feb 25, 2013 2:23 pm
by maci234
can anyone tell me if this will work with windows vista , as i have tried its not finding drivers or it states device drivers not updated any help thanks in advance
Re: bmw 140 scanner cant get it working
Posted: Mon Feb 25, 2013 3:07 pm
by jaynana
not sure on vista, this works on win 7 64 bit.
Posted: Mon Feb 25, 2013 4:06 pm
by Raj
It does work on vista as I have it installed. Think I had to plug into the OBD via the cable provided and then install the disc again. Just loading it into the laptop first and plugging it in doesn't do anything for some strange reason.
Posted: Mon Feb 25, 2013 4:38 pm
by LincsX5
It should work on Vista fine. If your having driver problems then disabling the signed driver check may cure your issue.
Open the Start menu and select "All programs."
Navigate to "Accessories" and right-click on "Command Prompt."
Select "Run as Administrator."
Type "bcdedit.exe /set nointegritychecks ON" in the black window and press "Enter."
Reboot the computer.
Read more: How to Disable Signed Driver Checks | eHow.com http://www.ehow.com/how_7310470_disable ... z2LvhJSvmG
Posted: Tue Feb 26, 2013 1:13 pm
by Steamyrotter
[quote="Raj"]
Poss as the interface derived power from the car rather than the USB port.
Therefore when not plugged into the car the PC won't see anything??
maybe?
Posted: Tue Feb 26, 2013 5:56 pm
by jaynana
correct as far as mine is concerned, although that applies regardless of the OS
that happened to me and then somebody here suggested that i try hooking it up into the car and then installing it. that worked as it got powered by the car.
it is easily observable - the power led comes up only when its hooked up to the car, not the usb.
Posted: Wed Feb 27, 2013 7:42 am
by marlin758
Only a long shot as I'm not sure how far you have got with the installation.
I seem to remember that it didn't install the drivers automatically but once you have installed the program there is a folder on the hard drive ( BMWScan ) with the drivers in and a .pdf file explaining how to install them .
Once the drivers are installed if you run the program you get an error if it isn't hooked up to the car
