BMW Scanner 1.4.0
Posted: Tue Apr 30, 2013 11:38 am
by malc1950
Hi can anyone tell me how to tun off the front PDCs with my scanner, what menu i go into i have been told its the ZKE menu but cant find any settings for the PDCs in there,  >:(
Re: BMW Scanner 1.4.0
Posted: Tue Apr 30, 2013 1:58 pm
by Raj
I think it's int he coding data option or something like that in the ZKE.
If needed I'll plug mine in this evening to confirm.
Posted: Tue Apr 30, 2013 3:31 pm
by malc1950
Hi Raj
To get into the PDC menu ,
Page 1 click on PDC then click on coding data then recoding,
Posted: Wed May 01, 2013 4:27 pm
by malc1950
Same problem , Yesterday I disarmed my front parking sensors 8 to 4 with my 1.4.0 scanner as I had a problem with a front sensor ,but now nothing is working and even the PDC switch won't work light up"
I thought you could disarm the front and just use the rear ?
Posted: Wed May 01, 2013 10:47 pm
by Raj
You should be able to disable the fronts and I'm sure some have done that when a front sensor is out.
Posted: Wed May 01, 2013 11:32 pm
by jaynana
i'm sure i've done this - change from 8 to 4 sensors and the fronts go off..
Posted: Thu May 02, 2013 10:13 am
by malc1950
I've been told to disconnect the blue plug from the PDC control unit in the boot then to alter settings with my scanner from 8 to 4 sensors once done
connect back the blue plug that should have turned off the front sensors ,
Will give it a go a the weekend ,
Sent from my iPhone 5 using Tapatalk
Posted: Fri May 03, 2013 12:29 pm
by Y13HYA
you still having these issues?
Posted: Fri May 03, 2013 1:30 pm
by Jamee
Sorry for the hijack, but all my sensors are clicking front and back, does mean both modules are gone?
Posted: Fri May 03, 2013 1:36 pm
by Lummox
Jamee your sensors are supposed to click. That is one of the ways to check they are working correctly.
Posted: Fri May 03, 2013 2:06 pm
by Jamee
[quote="Lummox"]
I know, but none of them actually work front or back when reversing or parking.
Posted: Fri May 03, 2013 8:04 pm
by Lummox
Jamee have you tried cleaning the sensors, i had this problem when i bought my car and i cleaned the sensors with a clay bar and they were fine after that. I was advised to try this by another forum as you can get a build up of road film/wax/polish, i thought the guy was mental when he suggested it but it worked for me.
Posted: Fri May 03, 2013 11:00 pm
by Jamee
Yes mate, tried cleaning them free of everything but no luck.
Posted: Sat May 04, 2013 6:21 am
by CondorX5
The PDC control unit itself might be faulty?
Posted: Sat May 04, 2013 10:07 am
by Jamee
Front and back???
