Window jam fix
Posted: Sun Jul 14, 2013 10:19 pm
by Imy
My drivers window had been getting jammed when it was opened all the way it refused to close. I had a few options to explore but went with the easiest first.
Turns out there are some plastic clips that hold the windows in place. Over time they can snap and leave the window out of position when all the way down.
Broken clip:
New clip:
Beats me why such an integral part would be made from cheap plastic but hey ho. Part cost £1.50 and did the job.
Window now closes and no more rattles when closing the door.
Thought I would share just in case anyone else has this issue, worth checking before doing the whole regulator.
Edit: apologies for lack of part number, will look it up.
Re: Window jam fix
Posted: Mon Jul 15, 2013 8:21 am
by Greydog
I have just this weekend had a similar problem rear window for me. It's scary that such an "up Market Marque" uses cheap plastic parts. Nothing wrong with plastic just I would hope that the best quality is used?
As all manufacturers use common parts across their model ranges this should be a worry to Rolls Royce buyers!!!
Re: Window jam fix
Posted: Mon Jul 15, 2013 10:42 am
by Jackstrath
Don't have a part number do you? I think the previous owner liked slamming doors as my drivers door rattles and the window has once refused to come up on its own ,
Figured it has maby fell out its rails or something and this topic confirms it
Got a part number for the bits ?
Re: Window jam fix
Posted: Mon Jul 15, 2013 11:16 am
by Imy
Sure do: 51338254781
When I checked in at my local dealer he checked his system and told me only something like 10 dealers in the whole country stocked the part so I ordered quite a few for futuer problems.
I also found a great write up AFTER I had finished, but to be honest its such a simple job, just a bit fiddly, that didnt really need write up:
http://www.frankies-bmw.com/X5series/di ... ow_fix.php
HTH
Edit: Should mention, what the write up excludes to mention is that you need to roll the window half way down or so until you can see the bolt through the metal frame as this is the only way you can access it, and whilst the write up says 3-4hrs, it actually only takes around 45-1hr.
Re: Window jam fix
Posted: Mon Jul 15, 2013 5:48 pm
Plastic gets used in all sorts of questionable places. It was a cheap plastic part in the torque converter that caused my transmission failure. Why a plastic part in a critical hi-load area was beyond me too, except they probably cannot reliably make it out of metal.
Well done for finding the fix though....
Re: Window jam fix
Posted: Fri Jul 19, 2013 11:14 pm
by Mick.H
Nice. This has just happened to mine. Thanks chaps
